S2 door latch replacement
I have a new door latch mechanism ready to replace the button-less original. Does anyone know if it is possible to replace the latch without taking the door completely apart? If it’s not too complicated (i.e., if I don’t have to remove the panel), I’ll do it now. Otherwise I’ll wait until I refurbish the doors this winter.
Andrew
Yes you can without gutting the door - I recall the whole shooting match comes out with with 3 or so fastners removed .
I just took the door latch mechanisms off both the doors of my S1. Driver’s side came out easily and quickly, pass. side I needed to remove the arm rest and the panel that you slide into place. Pass. side was still not a big job.
