s130 Wiper switch wiring
My wipers have only ever worked on fast, if you can call it fast…
Anyway on the back of my switch I have
Top left = Green and Yellow
Top Right =Blue and Green
Bottom Left = Brown and Green
Bottom Right = Red and Green
Could someone with a Uk +2 with working wipers please let me know if my switch is wired correctly
Matt
Hi Matt,
Mark kindly posted this for me when I was trying to fix my interior light switch - looks like yours is wired correctly
Thanks Robbie
Matt
Matt,
My +0 is wired completely differently. I don’t have a yellow/green wire, but I do have a white/light green one. Looking at the back of the switch:
Top Left: White/Light Green
Top Right: Brown/Light Green
Bottom Left: Red/Light Green
Bottom Right: Blue/Light Green
I have 2 speeds and after I lubed the motor, gearbox, and track, and then converted to an alternator, believe it or not, the fast speed is actually fast. Hope this helps.
Matt
The workshop manual shows for the 130 “S” NON-Federal:
top rt- yellow/green (With yellow green jumper to washer switch)
top lt- Brown/light green
bottom rt- Red/ light green
bottom lt- Blue/light green
Bob
Thanks for your help.
I’ve done more tests and the fault is with the Wiper motor.
Any one know what other car the motor is from ?
Matt
Matt, the motor is a fairly standard Lucas item. You can still get them for use in kit cars etc.
try looking under wipers here:
s-v-c.co.uk/
best regards, iain
