My understanding is that the original ccolor of the s1 frame was redish brown by viture of the redoxide coating used to inhibit rust. Yet I see lots of pictures of black frames ( i think used in later series cars) and frames powdercoated grey ( lotus space frames were almost always grey ( dark or medium) a color I am not sure they ever used for the elan
need a sanity check here because my inclination is to powercoat my S1 frame a color to match the red-oxide including low-sheen.
The black was bitumen (Tar-like) undercoating to prevent water from getting to the red oxide. My S4 had it and it seemed to work since there was no rust. Of course sitting for 20 years in garages helped.
I understand the replacement chassis are galvanized which would account for the grey color.
My S1 also had a red oxide frame. The best way I can describe it is “primer red”. Right now it is black from having it acid dipped and e-coated, but my plan is to have it powder coated in a red oxide color and then have a flat clear powder coat put over it to remove the sheen.
