Removing the Dash top
I’ve removed the Dashboard with the dashtop fixed to it. It appears to be held on with hundreds of staples, is there an easy way to seperate the two without wrecking the dashtop?
Jon
Hi Jon,
Sorry, but the only way is to slowly and carefully remove all the staples and this still leaves the crash pad in a bit of a sorry state. I take it you are replacing the dash, when Ive replaced a dash I havent restapled the crash pad to it, but put it back unattached…it goes back OK and looks fine. I think personally it makes life a bit easier.
Regards G…
Thanks, I was hoping there was a trick to it. There are Soooo many staples!
