Hello,
Noddy question. How do you get at the rear shocker tops?
I want to change shockers and springs to something a bit more beefy.
Andy.
Hello,
Andy.
Under rear parcel shelf on baby elan
Ian
aha, so I have about 75thousand little bolts to undo then
cheers.
There should be two holes in the parcel shelf through which you can get at the top fixing nut.
If you don’t have two holes, like I didn’t, then you have to cut them.
…usually fitted with rubber plugs.
Matthew
Spot on,
2 rubber plugs located! Nice one.
Andy.
I seem to recall removing the rear window.
Possibly to avoid the danger of a spanner slipping & busting the glass.
Ahh Bill, I have no rear window, so no spanner slippage fears!
