RB - Differential +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
1 A026R0702 1 Differential Assembly 3.77 : 1
3 A026R0004 1 Differential Case
4 026R0014 1 Gasket - Nose Piece to Differential Case
5 XUCS0516 8 Screw - Nose Piece to Differential Case
6 L05W0000 8 Washer - Nose Piece to Differential Case
7 A036R6038
(105E4017)
1 Differential Carrier
8 XUCS0516 4 Screw, Cap to Differential Carrier
9 L05W0000 4 Washer, Cap to Differential Carrier
10 A036R6017
(105E4676B)
1 Seal
11 A036R6034
(105E4859C)
1 Deflector
12 A036R6022
(118E4851B)
1 Flange
13 114274ES 1 Nut
A036R6020
(105E4662A)
1 Spacer - Pinion Bearing
14 A036R6026
(105E4616A)
2 Cup - Pinion Bearing
15 A036R6023
(105E4621A)
2 Cone - Pinion Bearing
16 A036R6040
(105E4672B)
AR Shim - Pinion Adjusting, 0.1314 - 0.1318 ins.
A036R6041
(105E4672B)
A036R6042
(105E4672C)
AR Shim - Pinion Adjusting, 0.1324 - 0.1328 ins.
A036R6043
(105E4672D)
AR Shim - Pinion Adjusting, 0.1334 - 0.1338 ins.
A036R6044
(105E4672E)
AR Shim - Pinion Adjusting, 0.1344 - 0.1348 ins.
A036R6045
(105E4672F)
AR Shim - Pinion Adjusting, 0.1354 - 0.1358 ins.
A036R6046
(105E4672G)
AR Shim - Pinion Adjusting, 0.1364 - 0.1368 ins.
A036R6047
(105E4672H)
AR Shim - Pinion Adjusting, 0.1374 - 0.1378 ins.
A036R6048
(105E4672J)
AR Shim - Pinion Adjusting, 0.1384 - 0.1388 ins.
A036R6049
(105E4672K)
AR Shim - Pinion Adjusting, 0.1394 - 0.1398 ins.
A036R6050
(105E4672L)
AR Shim - Pinion Adjusting, 0.1404 - 0.1408 ins.
A036R6051
(105E4672M)
AR Shim - Pinion Adjusting, 0.1414 - 0.1418 ins.
A036R6051
(105E4672N)
AR Shim - Pinion Adjusting, 0.1424 - 0.1428 ins.
17 2930E4209F 1 Crown Wheel and Pinion
19 A036R6037
(105E4205B)
1 Housing - Differential Gear
20 A036R6030
(113573ES)
6 Bolt - Crown Wheel to Housing
21 A036R6024
(105E4221A)
2 Bearing - Differential Gear Housing
22 A036R6025
(105E4222A)
2 Cup - Differential Gear Housing
23 A036R6016
(105E4067)
2 Nut - Differential Adjusting
24 A036R6028
(E0A4143A)
1 Lockplate, LH
25 A036R6027
(E0A4143B)
1 Lockplate, RH
26 A036R6031
(20310S7)
2 Bolt
27 A036R6032
(34806ES2)
2 Washer
28 A036R6036
(105E5211B)
1 Shaft - Differential Pinion
29 A036R6019
(105E4241)
1 Pin
30 A036R6039
(105E4236)
2 Gear - Differential
31 A036R6033
(2930E4228)
2 Thrust Washer
32 A036R6035
(105E4215)
2 Gear - Differential Pinion
33 A036R6029
(2930E4230)
2 Thrust Washer
34 036R6008 1 Drain Plug
35 036R6009 1 Washer - Drain Plug
36 036R6010 1 Plug - Filer/Level
37 036R6011 1 Washer - Filler/Level
38 A026R0009 1 Breather
39 036R6012 1 Washer - Breather
40 A026R0005 2 Drive Shaft - Inboard
B026R0005 2 Drive Shaft - Inboard
41 036D6017 2 Bearing, Optional
036D6016 2 Bearing, Optional
036R6005 2 Circlip - Internal (replaced by 036D6006)
42 036D6006 2 Circlip - Internal
036R6006 2 Circlip - External (replaced by 036D6007)
43 036D6007 2 Circlip - External
44 036R6007 2 Seal
