I’m starting the process to remove the engine from my Sprint, and am at the beginning stage, have the radiator out and most of the external bits removed. I’ve read through the archive and am choosing to remove the engine separated from the gearbox, and note that I’ll need to lift the engine up after removing the mounts in order to clear the front cross-member, then move the engine forward to separate from the bell housing dowels, then up and out. My question is- do I need to remove/loosen gearbox mounts in order to enable me to lift the gearbox as well to get a sufficient angle to move the engine forward?
Thanks!
Bill
This “seems” like it should be much easier than pulling the engine from my Europa…
I did the removal of my +2 engine a few months ago with the gearbox in place. I lifted the engine up a bit, then put a jackstand under the bellhousing. Didn’t touch the gearbox mount. Easy as.
no need to touch the gearbox bracket! make sure you protect the front edge of the bonnet opening, as some of us know: been there, done that AND that is a very visible place to have an “engine-touchdown” - i get an engine out in less than 3hrs. i guess some of you here can do it in 2hrs! sandy (4-5 hrs to get her back where she came from, is she a she?)
For my money i think it helps to slack of the two bolts that mount the rubber gearbox mount… Allows some lift. Also remove gear lever and cup. This allows the gearbox attitude to be lifted to aid engaging the two. Also prevents pulling on the gearbox rubber and tightness of the sump clearing the vac tank. No wishing to contradict but have done this way many times on both Elans and Plus 2’s.
Much appreciated- and thanks for the tip on the shifter
I’m approaching this a step at a time, like most new owners, I’m not sure what I’ll find as I go so it’s a bit of learning the car’s design and a bit of maintenance archaeology at the same time
I also heard Chapman was searching for a one-legged driver for F1 who would allow Lotus to have a narrower front end.
I don?t think one-leggedness would help you in repairing the car though.
Continuing to waste your time, I bought the shirt off the Team Manager?s back at a charity auction once - he was a skinny guy too - I can no longer wear it. If only I could remember his name …
