Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
028Q0703 | - | Replaced by 050Q6015 | |||||||||||
2 | 050Q6015 | 1 | Clutch Centre Plate | ||||||||||
026Q0702 | - | Replaced by 050Q6014 | |||||||||||
3 | 050Q6014 | 1 | Pressure Plate Assembly | ||||||||||
4 | XUFB0514 | 6 | Bolt, Clutch Assembly to Fiywheel | ||||||||||
5 | 115 | 6 | Washer, Clutch Assembly to Fiywheel | ||||||||||
6 | 036Q6004 | 3 | Dowel Pin, Clutch Assembly to Fiywheel | ||||||||||
7 | E70-7600 | 1 | Spigot Bearing, Close Ratio | Upto Engine No. LP7799 | |||||||||
105E7600A | 1 | Spigot Bearing, Semi-Close Ratio | From Engine No. LP7800 to ? | ||||||||||
036E6006 | 1 | Spigot Bearing, Semi-Close Ratio | From Engine No. ? to 18499 | ||||||||||
036E6019 | 1 | Spigot Bearing | From Engine No. 18500 Service Note ? |
8 | A026Q6114 (105E7500B) |
1 | Bell Housing | ||||||||||
9 | 27 | 4 | Bolt, Bell Housing to Engine | ||||||||||
10 | L06W0000 (34837-ES2) |
6 | Washer, Bell Housing to Engine | ||||||||||
11 | 25 | 2 | Bolt, Bell Housing to Engine | ||||||||||
12 | XUCB0408 | 3 | Bolt, Bell Housing to Engine | ||||||||||
13 | L04W0000 | 3 | Washer, Bell Housing to Engine | ||||||||||
14 | A036Q6040 | 1 | Release Bearing | ||||||||||
15 | A026Q6007 (125E7571) |
1 | Hub - Release Bearing | ||||||||||
16 | A026Q6004 (E308-CD-7) |
1 | Link - Release Bearing to Fork | ||||||||||
17 | A026Q6012 (109E7605B) |
2 | Clip - Release Bearing to Fork | ||||||||||
18 | A026Q60ll (109E7562) |
1 | Spring - Release Fork | ||||||||||
19 | A026Q6009 (109E7522) |
1 | Pin- Release Fork | ||||||||||
20 | A026Q6008 (109E7511) |
1 | Fork - Clutch Release | ||||||||||
21 | A026Q6003 (E335GD7) |
1 | Gaiter - Clutch Release Fork | ||||||||||
036Q6021 | - | Replaced by 026J6003 together with: 2 off 036Q0031 Bracket 1 off 036Q6037 Hose 1 off 036Q6038 Bundy Pipe 2 off L06W0000 Washer 2 off AUFN060F Nut 1 off A04W0904 Washer |
Upto Chassis No. 8849 Service II 1969/3 |
036Q6022 | - | Replaced by 026J6003 together with: 2 off 036Q0031 Bracket 1 off 036Q6037 Hose 1 off 036Q6039 Bundy Pipe 2 off L06W0000 Washer 2 off AUFN060F Nut 1 off A04W0904 Washer |
036J6053 | - | Replaced by 026J6003 | |||||||||||
22 | 026J6003 | 1 | Bundy Pipe | From Chassis No. 8850 | |||||||||
23 | 036J6037 | 1 | Hose | From Chassis No. 8850 | |||||||||
25 | 036Q6025 | 1 | Slave Cylinder - Clutch | ||||||||||
26 | 036Q6026 | AR | Repair Kit | ||||||||||
27 | A026Q6006 (E0A7059B) |
1 | Circlip | ||||||||||
28 | A026Q6005 (E310GD7) |
1 | Push Rod | ||||||||||
29 | 33923S | 1 | Nut, Slave Cylinder Push Rod to Operating Arm | ||||||||||
30 | E311GD7 | 1 | Nut, Slave Cylinder Push Rod to Operating Arm | ||||||||||
31 | A026Q6010 (109E7525) |
1 | Return Spring | ||||||||||
32 | 036Q6038 | 1 | + | Bundy Pipe - Master Cylinder to Bracket | From Chassls No. 8850 | ||||||||
036Q6039 | 1 | + | Bundy Pipe - Master Cylinder to Bracket | From Chassls No. 8850 | |||||||||
34 | 036Q0031 | 2 | Bracket | From Chassls No. 8850 | |||||||||
35 | AUF060F | 2 | Nut | From Chassls No. 8850 | |||||||||
L06W0000 | 2 | Washer | From Chassls No. 8850 | ||||||||||
A04W0904 | 1 | Washer | From Chassls No. 8850 |
