Item | Lotus # | All | +2 | +2 FED | +2S | +2S FED | +2S 130 | RHD | LHD | Description | Change Point Notes Bulletin Reference |
028Q0703 | 1 | Clutch Centre Plate (replaced by A036Q6044) | |||||||||
2 | A036Q6044 | 1 | Clutch Centre Plate | ||||||||
3 | 050Q6015 | 1 | Pressure Plate Assembly | ||||||||
4 | XUFB0514 | 6 | Bolt, Optional,Pressure Plate Assembly to Flywheel | ||||||||
A026E6068 (20326578) |
6 | Bolt, Optional,Pressure Plate Assembly to Flywheel | |||||||||
5 | L05W0000 | 6 | Washer, Optional,Pressure Plate Assembly to Flywheel | ||||||||
036M6246 | 6 | Washer, Optional,Pressure Plate Assembly to Flywheel | |||||||||
6 | 036Q6004 (E65-GC-1) |
3 | Dowel, Optional,Pressure Plate Assembly to Flywheel | ||||||||
7 | 113E7600 | 1 | Bearing - Clutch Spigot Shaft | Upto ? | |||||||
036E6019 | 1 | Bearing - Clutch Spigot Shaft | From Engine No. 18500 | ||||||||
A026E6046 | 1 | Bearing - Clutch Spigot Shaft | |||||||||
8 | A026E6114 (105E7500B) |
1 | Bell Housing | ||||||||
9 | 20488-S7 | 4 | Bolt | ||||||||
10 | L06W0000 (34837-ES2) |
6 | Washer | ||||||||
11 | XUCB0620 (20428-S) |
2 | Bolt | ||||||||
12 | XUCB0408 (20390-S7) |
3 | Bolt | ||||||||
13 | L04W0000 (34848-ES2) |
3 | Washer | ||||||||
14 | A036Q6040 | 1 | Release Bearing | ||||||||
15 | A026Q6007 (125E7571) |
1 | Hub - Release Bearing | ||||||||
16 | A026Q6004 (E308-CD-7) |
1 | Link - Release Bearing to Fork | ||||||||
17 | A026Q6012 (10927605B) |
2 | Clip - Clutch Release | ||||||||
18 | A026Q6011 (109E7562) |
1 | Spring - Clutch Release Fork | ||||||||
19 | A026Q6009 (109E7522) |
1 | Pin - Clutch Release | ||||||||
20 | A026Q6008 (109E7511) |
1 | Fork - Clutch Release | ||||||||
21 | A026Q6003 (D355GD7) |
1 | Gaiter - Clutch Release Fork | ||||||||
036Q6021 | - | + | Bundy (replaced by 026J6003 together with: 2 off 036Q0031 Bracket 1 off 036Q6037 Hose 1 off 050Q6011 Bundy 2 off L06Q0000 Washer 2 off AUFN060F Nut 1 off A04W0904 Washer) |
Upto 1479 Non Federal | |||||||
036Q6022 | - | + | Bundy (replaced by 026J6003 together with: |
2 off 036Q0031 Bracket 1 off 036Q6037 Hose 1 off 050Q6043 Bundy 2 off L06Q0000 Washer 2 off AUFN060F Nut 1 off A04W0904 Washer) |
036J6053 | Bundy (replaced by 026J6003) | ||||||||||
22 | 026J6003 | Bundy | From 1480 Non Federal | ||||||||
23 | 036Q6037 | Hose - Flexible | |||||||||
24 | 050Q6005 | Hose - Flexible | |||||||||
25 | 036Q6025 | Slave Cylinder | |||||||||
26 | 036Q6026 | Repair Kit | |||||||||
27 | A026Q6006 (9E0A7059B) |
Circlip | |||||||||
28 | A026Q6005 (E310GD7) |
Pushrod | |||||||||
29 | 33923S | Nut, Pushrod to Fork | |||||||||
30 | 311GD7 | Nut, Pushrod to Fork | |||||||||
31 | A026Q6010 (109E7525) |
Return Spring | |||||||||
32 | A050Q6011 | Bundy - Master Cylinder to Bracket | |||||||||
046J6043 | Bundy - Master Cylinder to Bracket | ||||||||||
33 | 050Q6000 | Bundy - Master Cylinder to Chassis | |||||||||
34 | 036Q0031 | Mounting Bracket | |||||||||
35 | AUFN060F | Lock Nut |
