Plus 2s courtesy lights
Anyone care to tell me how to remove the lenses on these? I need to check/change a bulb.
Ian.
There’s a small metal tab at one end. Push it in (horizontally) and the complete unit will lift out.
In line with Chapman’s philosophy of having a component serve more than one function, this tab is also the earth connection for the courtesy light. Corrosion on this might also be the problem.
Sean
