I about to replace the sills on my Plus and to set about removing the old ones from the rear. I spotted a thread that said they can be removed from the front so long as the front suspension is stripped which mine is.
Can any one confrm whether front removal is possible and whether it is any easier or more difficult than removing / replacing them from the rear?
Thanks for your help, I started to prepare to remove the driver-side sill this afternoon and so far I have stripped the interior of seats and carpets and to drill out the machine screws which run along the bottom of the sill. I had forgotten what a messy job this is having done this once before about twenty years ago on my 1st +2 FRU 124L. As there has been little response to my dilemma as to whether it is possible to remove / refit the sill through the front arch. I will attack the problem by going through the rear arches as this seems to be the most common way to carry out the sill replacement and therefore probably the best.
Peter,
I used stainless screws when I refitted mine. Metric are cheaper and more readily available so I used 6mm with penny washers. My car is going Zetec so originality is not important and I used hex head screws rather than slotted heads.
Peter
didnt reply as you were asking about replacing from the front…
when I did mine I did as most have probably done and done it from the rear…
its time consuming…mostly the getting rid of the old stuff…but the new stuff drops in fairly easily…
G
I endorse the stainless option, but went for Pan head screws ( google Namrick), and penny washers. Each washers had a chunk sliced off to fit - see pic. Watch out for the paint finish. It is proving difficult to get anything to stick to the screw heads and washers, which should have been etch primed before hand (My fault!). I am currently using black Hammerite, which seems to be staying put a bit longer.
Thanks, guys. Penny washers + stainless steel fasteners is a good idea. I spent most of yestarday preparing for the sill replacement with the removal of the interior and trim. Now for the really messy bit…
Only just seen your post. I did my sill members through from the front. removed the front coil spring damper then jacked the suspension up high. With all bolts removed and the kids as helpers to hold the sill out a bit ( about 1/2") the old one slid out and the new one slid in from the front with no problems and did cleared the front wing and body work with no problems.
I know its in the workshop manual but an update and experience thing is also good…
just as an aside…
Im on the LotusElanCentral site too with my m100 and we’ve started a wiki for people to put info and stuff like this…just gives another library resource…
I also used M6 stainless bolts and penny washers, I also had to grind back lay some new matt over the inner sill, the corrosion had forced the fiberglass out and begun to distort and split it.
As per previous posts, corrosion resistant fasteners is definitely the way to go. 316 stainless steel is a bit marginal for the crevice corrosion potential. 304 is even worse. F51 duplex or 6Mo would be ideal if anyone knows from where to procure (and I used 316 but would replace again if anyone can source say 6Mo). Button head with an internal hex makes for a nice finish (but again as per previous post, etch prime before painting it all black.
I have seen a lot of reference in this post about the benefits of stainless steel fixings. With regard to corrosion is not the issue one of dissimilar metal contact? when I did my sill members I used the Spyder ones–they are galvanised and came with a full selection of zinc plated fixings. I have always been led to believe that stainless steels in contact with with mild steel or galvanised / Zinc coated steel is not a good combination for exposed use.
The old sill member lower bolts came out easily I just drilled out the old bolt heads then they snapped off easily when spanner and screwdriver were applied. The internal bolts on the inner sill plates were more of a problem as the rot was so bad on sill member that a couple of the captive insert rotated and sheered in the metal ( or rust). I had to grind these out. The old sill member was steel and just painted and was the about 25 years old.
I have found that stainless steel bolts can bind and be very difficult to remove and drilling out would be very difficult.
My info is based on the attached file from an engineering magazine I picked up a (frighteningly!!) long time back. I am not a metallurgist or chemist so would be interested to have my knowledge commented on or corrected.
Bob, to address some of the valid issues you raise:-
1/ I’m biased in favour of stainless steel fasteners because I have stainless steel sills, supplied by SJ sportscars. These were fitted by the previous owner and within a couple of years the zinc coated fasteners had wasted away to such an extent that they were probably down to a 1/4 of the original x-sectional area and so very weak. The resultant ferrous corrosion product resulted in low pH within the fibreglass holes and hence damage to the “glass” fibres.
2/ So that’s my experience and bias out of the way.
3/ What to use for the zinc coated (galvanised) sills as supplied by Spyder. Well, if a short life and frequent replacement is not an issue, then zinc coated fasteners would be OK. Better still would be “olive drab” coated steel fasteners but even these will have a short life. Going to corrosion resistant fastener grades, some of the monels might be OK and your comments about dissimilar metals would generally be covered by the favourable area ratio between the small fasteners and the large galvanised sills. A method of equalising this a bit would be to apply a good paint coating to the sills.
4/ Stainless steels of the common austenitic variety are very marginal in wet chloride solutions and the presence of the zinc can tip them from being passive to “active”, in which case not much better than a steel screw but worse in many ways because also likely to crack under the high stress concentrations inherent within a fastener. Of course this applies to countries / road use on salted roads. If the car is in the garage all winter then obviously the risk is much reduced.
5/ To get an adequate corrosion resistance from an austenitic stainless steel, it’s normally necessary to increase the PRE number and the main constituent needed for this is a much increased Mo content. An example would be an Avesta “6SMo” grade. An entirely different route is to employ a mixed ferritic/austenitic structure such as a modern duplex or better still super duplex stainless with adequate metallurgical control and nitrogen content. Some of the common commercial grades make very good fasteners. Lots of benefits with this metallurgy: one of them is much reduced tendency to gall.
Gerry’s all stainless solution is obviously great but most of us have zinc/steel.
My experience with the standard setup on my first car and galvanised sills on the 2nd is that the worst corrosion of the screws is on the inside of the car (damp carpets?) where the screws pass through the sills. I suspect that moisture getting through the join and damp carpets are the main problem.
On my first car I used Waxoyl and mastic liberally on the replacement sills and galvanised bolts and they lasted extremely well. I also used mastic on the bumper bolts, again to good effect. Thirty years later, (the car has been off the road for most of that) everything cam apart very easily.
I have refitted the galvanised sills to car 2 as they were in good condition. I gave them a thorough coating of Dinitrol first. I think the key is really keeping the moisture out and I’ll be applying a stonechip or mastic on the outside, especially over the lower join.
From what I can see care is definitely needed in the selection of stainless steel fixings with mild/zinc plated steel components. In my car the sill members were corroded to absolutely nothing in places but all the bolts were still fairly intact they had to be drilled out because the nut had rusted on to the bolt such that screwdriver purchase could not undo them drilling the bolt heads made them easy to sheer off without damaging the fibre glass.
I have used a liberal amount of Waxoil on the new sill members so if they manage 20 years of summer only use should see me out!!
Of the commonly available stainless fasteners these seem to be sold as A2 and A4 grade. Looking on the web A4 looks to be a 316 equivalent that you describe as “marginal” in an earlier post --wonder what the marginal interpretation means? ( last 2 years or 10? – suspect this is a how long is a piece of string question).
I think if I used stainless fixings in the sill member application I would use one with a hex head or the button head style that would use a hex wrench so there would be good purchase to get them out later if required. Drilling stainless is a real pain!
Mine were done by the PO and looked good so left them alone. For later in your job, I paid particular attention to the wheel well sealing plates. Liberally coated with rattle can undercoat to keep moisture out of the rail plenum. The stuff I got kind of swelled with a thick application, which sealed the plate attachment points. Used caulking for the larger gaps. Spyder lists replacement closure plates if needed, or you can bash some up with galvanized sheet.
Used the same stuff to cover the rocker area. The jack pin tends to interfere a bit with the coating, so maybe check this area a bit during rail install.
I have finally managed to replace the drivers? side sill on my Plus. It?s not quite finished yet but at least we have some progress. I know that when I attack a job i like to see other owners experience so I have posted a few pics showing how I got along.
I know it?s possible to pull out the sill body work so you can clear the rear wing but I was unhappy to put so much strain on the glass fibre. I therefore tried removal from the front as I already had the front suspension stripped.
