I’m just in the process of refurbing my heater before I put the new dash in. Does anyone have a picture of the metal panel that moves to direct the airflow, I think it should have some rubber flaps/seals round the outside but there is nothing left on mine and I’m not sure how wide they need to be.
I have a complete heater box from my +2S out and in a storage trailer nearby. I’ll take a look tomorrow and see if I can post some pictures from all around. Not sure exactly what you are looking for in the way of pictures but I’ll get several and maybe one will be what you need.
Daniel,
I did mine earlier this year. After searching for a suitable alternative seal, I gave up and used strips of car inner tube.
The trouble is that my new rubber seal will not last as long as I had hoped a modern alternative would.
The picture attached was clipped from a larger picture but I hope it gives what you need, I don’t think the actual width is critical, its not an airtight seal. I triimmed the seal so that it doesn’t foul the rest of the box.
I did mine earlier this year too, I got new rubber strip from Woolies Trim, flat rubber strip 50mm x 1.5mm I think I cut the width down to the same as the original trim:
Um, sort of. This is an unusual '60s folding kayak / '60s Lotus question - I may have found my niche.
Rubberised fabric was used for folding boat hulls. Now the best (and better) alternative is Hypalon (it’s not vulcanised), which is used amongst other things to build and repair rigid inflatable boats (RIBs) these days. There are a couple of suppliers selling small repair sections on e-bay.
