Hi all, have just purchased a correct Girling Mk 2b Servo for my RHD 1973 Plus 2 but am in need of a mounting bracket, anyone have a surplus one available to buy or alternatively a sketch with dimensions so I could make one up, photos would also be useful. Is the finish gloss black or satin/matt. Thanks, Mike.
Here’s a pic of my early +2 servo you can just see the bracket. Also a pic from the parts list showing the bracket and backing piece on the wing underside. I can’t take dimensions as I don’t have the car now.
John.
Attached sketches that may help you with making a new bracket & if necessary the backing plate. Note that I made an oversize plate to improve the load spread which is shown along with the original sizes.
Have also included the setting out for the holes in the body but please check carefully on your car before drilling!
As for the colour, I will stick my neck out and say satin black similar to all other parts of this nature.
Hope this helps
Gary
159 Servo Bracket Backing Plate - Oversize.pdf (149.9 KB)
162 Servo Mounting Bracket - Holes in Body.pdf (124.0 KB)
164 Servo Bracket Backing Plate - Original Size.pdf (144.4 KB)
248 Plus 2 Servo Mounting Bracket Dimensions.pdf (256.5 KB)
Hi John
Thanks that is very useful.
Thanks Gary, that is very useful just need to find someone to fabricate it now.
