Afternoon all.
As the title says I’m after the dimensions of the Stud Plate that screws onto each end of the Plus 2 dashboard - these don’t seem to be available from the usual suspects so I’ll have to make them.
Specifically I need the relationship between the four holes for the screws that fix the bracket to the dash and and the two studs that are used to bolt the End Support Bracket (part no 050B1203 and 1204) to the plate; I can derive the spacing of the screw holes in the stub plate from my dashboard, and the spacing of the studs from my End Support Brackets but I need the positioning of the studs relative to the screw holes.
Unless of course if anyone knows where to get a pair of them or has a pair lurking in their spares boxes…
Matt
The plate is 4.5" x .750"
Like you stated, you can get the stud and mounting hole patterns from the mating parts, but here are the approximate dimensions from mine. It was a bit difficult getting on there to measure and the dimensions in inches looked off. When the calipers were set to metric they looked better.
The studs are 93mm apart and centered on the plate in both directions.
The mounting hole pattern is centered in both directions as well and is 74mm X 10mm.
I forgot to measure the studs but they look to be 10-32. The screw holes drilled to fit your mounting screws.
Hope that helps.
Hi Bud
Exactly what I needed many thanks
Matt
