Plus 2 130/5 door lights?
My December 1972 registered +2 130/5 has not one, but two contacts on the doors to control the interior lights.
I have just been told the extra switch is because the 130/5 models had ‘welcome’ lights in the doors - mine doesn’t seem to.
Is this info correct, or in typical Lotus fashion have I something missing? A photo of what should be there would be fantastic.
Mark.
Hi my 1972 plus 2 has welcoming lights about 12 inches below the door catch inlaid into my doors,they have a red lense which show rearwards when doors open…
My Nov '72 +2 also has 2 plunger switches, the rearmost one works the interior lights, whilst the front one works lights in the rear edge of the door which are positioned as “rocket” says. I found the contacts of the door switches corroded and had to remove them (by crawling into the footwells and undoing a nut from the inside) and clean them up before they’d work.
If I remember rightly, my '73 plus 2 also has “puddle lights” in the bottom of the doors in addition to the rearward facing red “warning lights”. The puddle light lenses are white.
Interesting that Barry.
I know see in Paul Matty’s catalogue ‘puddle lights’ are listed (although I don’t know whether they are still available). It makes no listing on the red rear facing ones.
Are they large lights or just small red ones like dash warning lights? :confused:
Mark.
This is what the red light in the passenger door of my 1971 S130 looks like.
MJS, MY 1972 PLUS 2 4 SPEED HAS WHITE PUDDLE AND REAR FACING RED DOOR LIGHTS, ALL CONTROLLED VIA ONE DOOR PLUNGER SWITCH. THE WHITE PUDDLE LIGHTS ARE AVAILABLE NEW (TRIUMPH ITEM).
REGARDS
My 1968 +2 has puddle lights so I suspect they are a standard item.
And a very nice touch I think!
Thanks everyone. I can only assume when the body was rebuilt by the PO it has had a change of door. Will set out to bring things back to spec. Cheers.
MJS.
Good picture of the red light on rearward edge of door but where is the so-called puddle light, that is supposedly white, located; anybody post a pic, thanks Gordon Sauer
Picture of the white puddle light taken from underneath the passenger door of my +2 S130.
My +2S (1970) has the rear facing lights so I guess they came in with the +2S i.e. before the S130.
