New Plus 2 S130 dashboard
Today my new dashboard arrived, after a long wait. I must say, the quality of the work is astounding. The finish is like glass. I’ve tried to capture this in the pictures but I don’t think they do it much justice. See what you think…
Very Nice Jon. Supplied by Classical Dash?
Robbie
Seen some dash lamps in my time but never a multi branch one!
Oh, that’s a reflection of the chandelier in the dining room.
No, it’s not from Classical Dash. I think they are a bit expensive… plus reports like this do not instil confidence: http://www.lotuselan.net/forums/lotus-elan-f19/classical-dash-beware-t39507.html
My dash came from Nick Martin: http://www.nicholas-martin.co.uk. ?170 + ?20 shipping. There may be a backlog, but it is well worth the wait. I think he makes them to order. I have never seen wood look this good. If you examine the glove box door you’d swear it was made of glass, such is the perfection of the finish on the lacquer. The rest of the dash is the same. It came wrapped in cotton wool (no, really) over a layer of bubble wrap, sandwiched between two sheets of plywood, with a thicker sheet to prevent it bending for good measure. Then the whole thing was wrapped in industrial cling film (the sort of stuff pallets of boxed goods are wrapped in), so it arrived in one piece with zero damage. It’ll feel like sacrilege drilling the holes for the glove box hinge and catch. I specified walnut veneer on both sides (contrary to “standard”, which is walnut on the front but some ordinary stuff on the back).
I’d not heard of Nick but it looks like he was formerly known as City Polishers.
It’s the first time I’ve seen the heater labelling done fully, i.e. with the arrows and blocks. These are usually missing, did you have to specify features like this or did they come as ‘standard’?
Jon,
If I may offer some hard learned advice,
Test fit the bare dash to the car, you may also need to remove some of the mounting bolt sleeves from your old dash, so be carfeul not to chip that lovely laquer when refitting them.
Then, test fit all the switches and gauges, as you may need to relieve the holes for both perimeter and depth, in fact test fit all fittings. It?s much easier done on the work bench,
Also when it comes the gauges (especially speedo, Rev counter), allow enough slack in the wires to allow easy removal of the gauge once in situ.
…and no harm in investing in a half loom,
… assuming you have a voltage regulator somewhere, consider changing to a digital one,
… and make sure the first thing you do is remove the battery!
Good luck and enjoy.
Peter
Peter, I am open to all advice on this. The car is still in one piece. I plan to wait until it’s warmed up a bit out there, then remove engine & gearbox (they need new oil seals, clutch needs an overhaul and the gearshift is up for some of the old “Vince Reynard magic”). With these out I will be able to remove the ambient temperature gauge sensor and its capillary pipe with reduced risk of damage.
I’ve got to confess that I’ve got a lot of trepidation about the whole thing, having seen pictures of what is behind the dash (a scary looking mess of wiring) and I’ve already encountered Lucar connectors that seemed to be fused together and couldn’t be separated. It’s a bad design, because you cannot get at the bullet to separate it; you have to pull on the wire itself. Bad, as they often snap.
Regarding the voltage regulator, I already bought the parts to convert the thermoelectric one to solid state.
The trial fitment of gauges and switches is a given. I think you have to prepare the whole dash with all fitments on the bench prior to fitting and I’ve seen people attach sublooms to it as well. I recall that some multi block connectors were used too.
I have a question about the switches. What’s the best way to ensure they are centred in the holes prior to drilling and screwing them in? Is there any adjustment possible (for example, oversized holes in the switch fixing tabs)?
Finally, does the original loom use “flag” connectors for the gauges (I’m expecting they do not, but thought to ask anyway).
Can’t really help with the questions but in some ways I’d almost prefer to have a slightly further from perfection dash turn up. When you come to fit it there’s bound to be the odd scratch or chip creep into the process and you’ll be hit with ‘I’ve ruined it’ guilt - or I would be anyway. :frowning: The earlier Elans seemed to have a less glassy finished dash that look like they’d withstand a bit more manhandling.
My current dash - and the mess behind it - badly needs replacing so I may be facing the reality of it all later in the year but I’ve got a couple of extra instruments and a few switches that need extra holes drilling / cutting. Standing in front of your dash, hole saw in hand, would definitely cause a few palpitations.
Jon, is the dash veneered or is it a solid hunk of wood?
I recommend eliminating the bullets and using some sort of multi-pin plug. I’m using two 15-pin Molex plugs, and I’ve got them oriented so that one is male on the dashboard side of the connection and one is male on the car side, so that they can’t be cross-connected.
If I was redoing that rat’s nest I would rewire the entire dash to modern multipin connectors. Then mod the existing loom to suit. (Plus the column switches).
You could then wire the dashboard on a soft surface, eliminate excess wires and do it in the warm.
Then just slip it into place as virtually one piece. Far as I remember you need the driver air vent out to access the speedo and the speedo out to access the tacho.
Veg beat me to it!
It’s a plywood veneer. As original, I believe. A lot browner than I was hoping for - I got used to the light tan colour of my original dash, but there is too much damage to restore it (nice chunk of veneer missing above the radio).
I’ll look into Molex connectors. Is there space to fit them? Must be…
@Vince: New speedo cable needed, the needle jumps around a bit at low speeds. Also, noticed on today’s maintenance drive that cold air is is coming through a gap between the dash and trim. It’s the vent trunking connection, I’ll warrant. I’ve seen pictures of how bad a fit it is.
That could be a job to add to the engine out list. The gearbox speedo drive CAN be a bugger to reach. Toad is OK as I fettled it a bit to point in the right direction.
You need the “dismountable” gearlever, it makes all this faffing a lot easier.
You think I should attempt the lever mod with the box in situ…?
Thread Creep!
The lever mod (as in making it “take apartable”) is not the same as modifying the crossshaft position.
Your floppy gearchange could be that the rubber bellows / spring is split and / or the nasty circlip is missing.
If you can rattle the lever in a vertical position the bellows/ spring is not working. With the mod. it allows you to adjust the tension. Note white cable tie reinforcing the bellows - they split at the top.
It also makes removal / installation of the lever far less of a swearing / 3 handed job.
Nothing to do with the dashboard but it might allow access to the speedo. cable easier.
I note the Autocar '72 roadtest compains about the gearchange baulking in 1st and 3rd so it seems quite normal!
What’s that hex bolt doing securing your dash, Vince?
:open_mouth:
Jon, lots of good advice from the rest of the team. I particularly like the idea of modern connectors rather than bullets which take up a lot of room, especially at bulkhead join and are unreliable by modern standards. If you stick with bullets then use electrical lubricant which allegedly improves the connections.
In terms of aligning the switches I think I used lolly sticks or the like to get the correct spacing but still did the final alignment by eye. That?s where the oversized holes on the switches save the day.
Reading through the posts reminded be of few further things to think about.
  • don?t get the switches the wrong way around otherwise the windows will go down when you press the up.
  • wrap plenty of tape around the gear stick fitting, otherwise that will be the first scratch on that lovely dash.
  • loosen but better remove the steering column.
Now further mission creep, as you are doing much more than changing the dash. So here goes while you are at it-
  • remove and refinish the metal demister grills if looking a bit tired
  • check the wind screen washers and wiper mechanisms
  • remove the pedal box and reinforce the aperture.
  • fit a battery cut off switch to the main steering column mounting bracket, it?s very out of the way there and very descrete.
Oh, did someone say overhaul the heater?
Why - because you know you want too!
Peter
Heater overhaul and steering column bushes are on the to-do list. Pedal reinforcement, too. Why fit a cutoff switch, is it for security? I have an immobiliser.
I may be mistaken but i believe thats who supply Sue Miller with her dash’s… The S4 dash i bought from her had a small City Polishers label on the back, the finish on that dash was also stunning.
Jon, have you test fitted a switch yet? the switch holes on my dash are bigger and it took a bit of messing about to get them centered, some thing else to consider is blanking the space round the switch out with some foam etc to stop the dash lights bleeding through the gap at night (i used smiths gauge bezel seal, assuming you need it of course) o and if you use new screws make sure their plated not stainless (if for any reason in the future you need to remove some thing a magnetic screw driver makes life so much easier)
No, not test fitted anything. My car is still in one piece - old dash still in place. I haven’t started yet… first job is engine & gearbox out, but not until Spring.
