I’ve been a 5 year Lotus owner, driving an arctic silver Elise. I’ve loved that car so much that I wanted to pair that with some kind of classic Lotus from the Chapman era. I’ve searched for the right Europa, Esprit, or Elan for several years.
Today my search finally ended, taking possession of a 1974 Lotus Elan Plus 2. It’s in reasonably good shape, very good even, and the right color for me. The one compromise I made to end my search was it’s an Elan Plus 2, which means it’s a right hand drive car. That is going to take a lot to get used to. That and driving a 49 year old car.
While I love cars, I have almost no skills in fixing cars and always have mechanics take care of my cars. I know a lot of Lotus owners get under the hood, or even the car and get to work, but that’s not me unfortunately.
While my Elan Plus 2 is in very good shape, it does need a few items looked at and replaced like tires and most likely the rotoflex couplings. I won’t get much mileage behind the wheel until I have those items fixed. Tomorrow I go apply for plates for the car and then I’ll maybe drive it around the block a few times to try to calibrate my arm to the gears and my foot to the clutch. By the way, the clutch has a very short feel to it.
I hope my new owner questions are not too boring. I’ll search the forums for answers but I do hope to connect to folks here, especially anyone in the metro Detroit area. (I’m in Ann Arbor).
Yep. That’s the one. It sure is pretty. However, I find my garage has a gasoline smell now with this Lotus stored inside so there is a vapor leak of some kind. Underneath the car is dry.
Thanks for the pointer. I’ve done a little reading based on your post and I’m wondering, does my car have to be disassembled to some extent to get to the vents? I saw a few photos where it looked like the rear windshield had to come out. I would hate for that to have to happen but if that fixes the problem, so it goes.
I wish I were a wrencher but I have no abilities in this area so will have to get it into the shop once I have plates for the car.
Fuel smell after using it is normally the fuel evaporating out of the carbs (hence the much debated long turn over to cold start this car).
Longer term smell will be the tank vent lines as mentioned. There’s ways to fix/improve it. Your cars so original might be a shame to go messing with it though. Quick fix is a couple of bungs in the vent pipes and just remove them when driving it filling the car up.
Forgive my noob question but are these pipes easily assessable? The photos I see all have the car partially disassembled. I would love to plug these up right now. The gas smell in my garage is strong enough that I think I need to remove the car and put it on the street.
If I could plug these vents up and eliminate the potential fire hazard, that would be wonderful.
They come out basically under the rear seat bases, they are hard to see unless your under the car. But put your hands under and feel a few inches under the floor and you find the raising edge of the seat base that they come through.
To mod the tank you just need to remove the rear seats and parcel shelf. It’s about four screws, one of those easy to remove but much tricker to refit…
That’s a beautiful car! I think you’ve got the best colour but then I am a bit biased! (note my avatar)
“…it’s an Elan Plus 2, which means it’s a right hand drive car.” Not necessarily. They did sell LHD Plus 2s over here until about '71, shortly before the 5-speed became available. Mine is one of those ‘Federal’ cars, although it bears British reg-numbers due to the first owner picking it up at the factory then staying in the UK for a while. Interestingly though, a couple of years ago I did drive a yellow RHD Plus 2 around a few blocks of Los Angeles. Not your car though, this one was a bit earlier and less-shiny and I seriously doubt that its owner would ever part with it. I found it easier to drive than I expected it to be. The different motions came much more naturally than I’d anticipated.
BTW I lived in Ann Arbor as a toddler; my family moved south shortly before my 4th birthday. We lived on Church Street near the university.
You should consider CVJs for replacing the Rotoflexes. There are probably even more discussions about that here than about the fuel tank venting. You can get them from pretty much all of The Usual Suspects (the vendors who sell parts for old Lotuses). While purists insist on the Rotos for two-seat Elans, they’re really below what the heavier Plus 2 needs.
Best of luck with the car and keep us posted on your adventures with it! This is a great community full of helpful folks and you’re in great company here.
Thank you for the warm welcome. I will consider replacing the Rotoflexes with CVJ’s. I’m afraid that I have started my first adventure already. Something seems to have broke which will be the subject of my next post.
