Hi Everyone.
My first post on this forum, so here goes I am taking delivery of a sprint dhc this wekend which is in need of some serious TLC.
It has had a new Lotus galv’ chassis about 3 years ago so I don’t think it will need the body off. Plan ‘‘A’’ (providing inspection goes to plan )
is to remove and renovate each corner with whatever is needed to bring up to spec’.
Question…being away for so long (I sold my +2 s130) quite some time ago) I have lost touch with what’s what so… What about mods? Anything recomended whilst I have the suspension/brakes etc off the car? New poly bushes for eg?? How’s about brake parts? Uprated discs/calipers??
I aim to strip off each corner, beadblast carefully any parts needing painted, powdercoat where applicable, then rebuild. Engine is fine. Body will need painted but is good. Interior is tired but complete and intact.
The car has a genuine lotus hard top with it. Does anyone know how this attaches to the top of the screen and to the rest of the car for that matter?
Welcome to the forum - as Pete says there are a lot of tips hidden away here although sometimes a bit of digging via the “search” is needed.
I have recently started getting my Sprint FHC back on the road after a long lay up and after some debate with myself and others so far I have done the following, which may give you some ideas.
Front
replaced old wishbones with Spyder tubular ones
dump servo and replace front caliper/disc and dustshield with the + 2 ones
uprated Spyder antirollbar
poly bushes for ARB and trunnions
my trunnions and stub axles were worn so replaced
Rear
-New Spyder adustable A frames
-Syder RSC conversion
Sue Millers driveshafts
new discs and exchange calipers
When the credit card has recovered then am proposing
alloy fuel tank
alloy radiator
alternator conversion
Spyder have been very helpful for powder coating or black etching of parts if you don’t have anyone local.
Thanks for that people. I think the old credit card is going to get a melting here.
As far as the hardtop goes… It has a Lotus Lable on it! The car was owned for the last 20 years by a doctor who never fitted it to the car. Are they hard to come by? I almost said keep it/bin it I don’t want it etc. As I won’t use it during winter etc I was not sure I was going to uplift it with the car. I was going to ask his wife to dispose of it. Mistake??
By the way… The gentlman died recently hence car was sold.
If you look back through the postings there is quite a bit on removing the servo - or not! I understand that the +2 front brakes are a worthwhile upgrade and the other thing that swayed me is that the cost of a refurb for the servo seems astronomical. I still have some work to do and have not finished refitting everything - I may leave the unplumbed servo in place for appearance.
Have a look at the Spyder website for info on the RSC.
Had a read regarding servo removal. Looks like the troops are trying to achieve a firmer pedal. V difficult! Never really managed this on my +2s'. Problem was piston travel in the callipers. Any slight run out on the discs at all = excess travel = soggy feel to the pedal. I think I will have a go with the new discs, ss hoses etc 1st then report back.
I also had a look on Spyders web and I like what I see. That rear end conversion looks cool. What effect do any mods make on car value. Is it better to keep it as near standard as poss' in that respect? I may be forced into repacing bits but I don't know yet as I have not been under the car as such. I pick it up this friday!
A Good clean is 1st! :confused:
Thanks for that. Another bit learnt! Think of the dosh I can save !!
I am in Dunfermline area…Still…
My +2s' were reg LMP413K (s130) and 1053K (STD +2)
LMP had its roof removed Still have pic’s of it during Club Lotus track days at Knockhill. Got fairly respectable times. Went home with no brakes or tyres…
On an Elan, a respray usually is the single most expensive item on the list, don’t underestimate it. It’s not a matter of spraying on new paint. For a nice result which will last many years you need to build up new gel coat.
Costs are very much dependant on labour rates and condition of the body, but can be anything from 2500 BGP to 6000 GBP And you need to find someone who is really experienced with GRP, but this should be no problem in the UK. Anyway, it’s worth it!
Thanks again guys. I can’t believe the help and advice I am getting here,
It truly is brilliant. Please keep it coming.
Roof… struth! I will bring it home with me then. But How does it fit on?? Anyone ?? Looks like rain am friday (when I collect the car) and the hardtop could be a godsend.
Paint… Yep I was budgeting for at least 2K. My mate is restoring a californian Daimler Dart SP250 and used a local GRP expert who charged him 1800 nicker and the body is braw. So I am going to the same place. I recon 2 - 3 K will do it ok. The body really is quite good so I don’t expect any shocks here.
Mods etc/Corner at a time… Yes good advice thanks. I will be doing an axle at a time really and no rush. First job will be a good clean of the engine bay and a thorough inspection. Depending on findings I will then either A) get stuck into it , or… B) ferry the car up for painting after stripping out interior removing doors, bootlid,bonnet, lamp pods etc etc. And leaving it with the paint shop over the winter letting him get on with it as n when. I have other cars so I don’t need it for transport so no rush at all really. I will just have to put up with my Z4 Needs must eh!!
Hi again all,
Well, its on my driveway The run down with it went very well. No major snags. Runs straight n true brakes quite well and not too noisy… Fuel guage u/s… panel light on = tacho on.off.on etc. So I suspect a bad earth somewhere. One or two wee leaks is all. Door locks don’t work, and can’t get the seats to move.
All n all not too bad…
Going to try n fit the hard top in the interest of security till I get it into the workshop. Great big security lock on the little steering wheel at the moment.
Hopefully the car!.. I had a +2 std wheel with chapmans sig’ on it hanging in my workshop for a few years. In walked a lotus owning person and said ‘‘I could do with that’’ so I handed it to him!
Hatman… Yes it is. I thought it had been withdrawn though. V def’ now sold.
progress report…
Fixed the few lec’y problems. Bad earths everywhere. Diagnosed the fault in the fuel guage to a faulty sender . Removed the firmly stuck drivers seat and found one of the small pads had broken off the seat frame. Removed both runners for now and replaced with home made stainless ‘runners’ for the seat to rest on. Welded the broken ‘pad’ back onto the seat frame and glued on a pc of rubber ‘cushion’ which rests nicely on the stainless strips. This allows better accesss to the rear of the seats … for now. I am going to refurb the runners and refit them when I retrim the car.
Cleaned out the boot…
Other seat out tomorrow for same treatment clean etc. And I might just open the bonnet.
Question… I take it these engines do not like unleaded as there were lots of additive bottles (some full) in the boot. 1 bottle per (40ltr) tankfull? The car has a nice ally tank. Any ideas about its capacity? Do I need to use the addtive??
This is from a Lenham hardtop brochure and may give some clues:
“The Lotus Elan hardtop is craftsman made from strong but light glass fibre and is painted black or to match your car.The inside is finished in grey cloth.There are rubber seals to all surfaces.The top hooks over the alloy strip across the screen and is held at either side with bolts that hook into the hood frame pivots”
