MF - Electrical - Windscreen Wiper +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
050M6000 1 Windscreen Wiper Motor (replaced by 050M6111)
050M600A 1 Windscreen Wiper Motor (replaced by 050M6111)
1 050M6111 1 Windscreen Wiper Motor
XUFS0416 2 Screw - Windscreen Wiper Motot Mounting
2 046M6155 1 Mounting Bracket
3 050M0010 1 + Bundy - Motor to Wheelbox
050M0003 1 + Bundy - Motor to Wheelbox
4 050M0011 1 Bundy - Wheelbox to Wheelbox
5 026M0012 1 Bundy - Wheelbox to End
6 036M6015 1 Grommet - Bundy to Bulkhead
7 036M6151 2 Wheelbox
050M6004 1 + Windscreen Wiper Arm RH Upto ?
050M6004A 1 ± Windscreen Wiper Arm RH Upto ?
8 050M6106 1 + Windscreen Wiper Arm LH From ?
A050M6190 1 + Windscreen Wiper Arm RH Upto ?
050M6003A 1 + Windscreen Wiper Arm RH Upto ?
050M6103 1 + Windscreen Wiper Arm LH From ?
9 050M6105 2 2 Windscreen Wiper Blade Upto ?
050M6005 2 Windscreen Wiper Blade From ?
10 050M6104 1 Windscreen Wiper Arm (straight) Driver’s Side From ?
A050M6189 1 Windscreen Wiper Arm (straight) Upto ?
050M6002A 1 Windscreen Wiper Arm (straight) (satin) From ? to ?
11 050B6136 1 Spacer
12 050B077 1 Washer Unit Upto ?
050B6000 1 Washer Unit From ?
13 050B6001 1 Washer Reservoir
14 036M6085 2 Jet
050M6005 1 1 1 Washer Unit
15 036M6159 1 1 1 Washer Unit
036M6260 1 1 1 Washer Pump
050M6003 1 Tube - Bottle to ‘T’ Piece
050M6004 2 Tube - ‘T’ Piece to Jet
050M6002 1 ‘T’ Piece
