Item | Lotus # | All | +2 | +2 FED | +2S | +2S FED | +2S 130 | RHD | LHD | Description | Change Point Notes Bulletin Reference |
1 | 036M6017 | 1 | 1 | Control Box | Upto 1588 also installed in 0978, 0982, 0984, 1304, 1310, 1469 and 1470. | ||||||
2 | 050M6108 | 1 | 1 | Control Box | From 1589 | ||||||
050M6108 | 1 | 1 | Control Box | From 1593 to ? | |||||||
XUFS1008 | 2 | Screw, Control Box to Body | |||||||||
A03W0605 | 4 | Washer, Control Box to Body | |||||||||
YUFN100F | 2 | Nut, Control Box to Body | |||||||||
3 | 036M6018 | 1 | Fuse Unit | ||||||||
RSTS1016 | 1 | Screw, Fuse Unit to Body | |||||||||
KSTS0412 | 1 | Screw, Fuse Unit to Body | |||||||||
4 | 036M6019 | AR | Fuse, 35 amp. | ||||||||
A050M6167 | AR | Fuse, 5 amp. | |||||||||
5 | 036M6247 | 1 | Fuse Cover | ||||||||
6 | 050M6092 | 1 | 1 | Fuse Unit | |||||||
050M6093 | 1 | 1 | Fuse Unit | ||||||||
XUFB0324 | 6 | 6 | Bolt, Fuse Unit to Body | ||||||||
A03W0806 | 6 | 6 | Washer, Fuse Unit to Body | ||||||||
YUFN030F | 6 | 6 | Nut, Fuse Unit to Body | ||||||||
050B1799 | 2 | 2 | Spacer, Fuse Unit to Body | ||||||||
7 | 050M6063 | 3 | 3 | 3 | Relay - Side Lamp, Headlamp Main Beam and Headlamp Dip | ||||||
036M6026 | 1 | Relay - Headlamp Main Beam | |||||||||
8 | 050M6013 | 1 | Relay - Horn | ||||||||
9 | 050B1763 | 1 | 1 | 1 | Heat Shield | ||||||
036B6123 | 3 | 3 | 3 | Rivet - Heat Shield Mounting | |||||||
10 | 050B1764 | 1 | 1 | 1 | Relay Mounting Bracket | ||||||
036B6207 | 1 | 1 | 1 | Flasher Unit - Hazard Warning | From ? | ||||||
11 | 036M6100(?) | 1 | 1 | 1 | Flasher Unit - Hazard Warning | Upto ? | |||||
054M6049 | 1 | Flasher Unit - Hazard Warning | From ? | ||||||||
054M6050 | 1 | Bracket - Flasher Unit Mounting | Upto ? | ||||||||
12 | 036M6025 | 1 | Relay - Headlamp Flasher | ||||||||
036B6026 | - | Relay - Headlamp Flasher (replaced by 050M6063) | |||||||||
050M6063 | 1 | Relay - Headlamp Flasher (Continuous rated) | |||||||||
050M6064 | - | Bridging Lead - Main Beam Relay (replaced by 050M0107) | |||||||||
050M0107 | 1 | Bridging Lead - Main Beam Relay | |||||||||
RSTS1008 | 4 | Screw, Relays to Body | |||||||||
036B6003 | 4 | Nut, Relays to Body | |||||||||
A050M6170 | 1 | 1 | Relay - Sidelamps | ||||||||
13 | 036M6022 | 1 | Flasher Unit - Headlamp | ||||||||
RSTS1008 | 2 | Screw, Flasher Unit to Body | |||||||||
036B6003 | 2 | Nut, Flasher Unit to Body | |||||||||
14 | 036M6024 | 1 | Flasher Unit - Direction Indicators | ||||||||
036B6123 | 1 | Tap-it Fastener - Flasher Unit to Body | Upto 1750 | ||||||||
036M6272 | 2 | Clip, Flasher Unit to Body | From 1751 | ||||||||
036B6001 | 1 | Nut, Flasher Unit to Body | From 1751 | ||||||||
W0092 | 1 | Cup Washer, Flasher Unit to Body | From 1751 | ||||||||
KSTS0616 | 1 | Screw, Flasher Unit to Body | From 1751 | ||||||||
15 | 036M6334 | 1 | 1 | 1 | Flasher Unit - Hazard Warning | ||||||
16 | 036M6300 | 1 | 1 | 1 | Flasher Unit - Direction Incidators | ||||||
050M6054 | - | Votlage Stabaliser (replaced by: 050M6096 together with 1 off 050M0106 Earthing Lead 1 off KWDS0608 Screw) |
17 | A036M6326 | 1 | Relay - Steering Buzzer | ||||||||
18 | 050M6125 | 1 | Buzzer - Steering Lock | ||||||||
19 | 050M6096 | 1 | Voltage Stabiliser | ||||||||
20 | 050M6107 | 1 | Choke - Stabiliser | ||||||||
050M0106 | 1 | Earthing Lead | |||||||||
KWDS0608 | 1 | Screw - Stabiliser to Facia |
