MA - Electrical - Engine & Horn
Item Lotus # All S1 S2 S3 S3 SS S4 S4FED SPRINT RHD LHD Description Change Point
Notes
Bulletin Reference
026M0704 1 1 Wiring Loom, Main
026M0703 1 1 1 Wiring Loom, Rear
026M0054 1 1 Wiring Loom, Courtesy Light Switch
026M0052 1 1 1 + Wiring Loom, Foot Dip Switch
036M0704 1 Wiring Loom, Main
A036M0704 1 Wiring Loom, Main
036M0703 1 1 Wiring Loom, Rear
036M0717 1 1 Wiring Loom, Boot Lid
036M0054 1 1 Wiring Loom, Courtesy Light Switch
A036M0721 1 + Wiring Loom From Chassis No. ?
036M0722 1 + Wiring Loom From Chassis No. ?
036M0741 1 Wiring Loom, Main Window Lift
036M0742 1 Wiring Loom, Door
036M0747 1 Wiring Loom, Engine Bay
036M0747 1 Wiring Loom, Engine Bay Upto Chassis No. ?
A036M0747 1 Wiring Loom, Engine Bay
A036M0747 1 Wiring Loom, Engine Bay From Chassis No. ? to ?
B036M0747 1 Wiring Loom, Engine Bay From Chassis No. ?
036M0748 1 Wiring Loom, Facia
A036M0748 1 Wiring Loom, Facia Upto Chassis No. ?
A036M0748 1 Wiring Loom, Facia From Chassis No. ? to ?
B036M0748 1 Wiring Loom, Facia From Chassis No. ?
036M0749 - - Replaced by B036M0749
A036M0749 - - Replaced by B036M0749
B036M0749 1 Wiring Loom, Rear From Chassis No. ?
036M0764 1 Jumper Lead From Chassis No. ? to ?
036M0765 1 Jumper Lead From Chassis No. ? to ?
A036M0134 1 Flying Lead From Chassis No. ?
A036M0135 2 Flying Lead From Chassis No. ?
A036M0136 2 Flying Lead From Chassis No. ?
A036M0144 1 Flying Lead From Chassis No. ?
A036M0145 1 Flying Lead From Chassis No. ?
A036M0140 1 Flying Lead From Chassis No. ?
036M0125 1 Earth Lead From Chassis No. ?
036M0790 1 1 Extension Lead - Window Lift From Chassis No. ?
A036M0141 1 Lead, Hazard Switch to Hazard Flasher From Chassis No. ?
A036M0142 1 Lead, Hazard Switch to Indicator Flasher From Chassis No. ?
A036M0143 1 Lead, Relay Switch Flasher Unit From Chassis No. ?
A036M0147 1 Lead, Feed to Hazard Switch From Chassis No. ?
A036M0148 1 Lead, Hazard Switch to Steering Column From Chassis No. ?
A036M0149 1 Lead, Hazard Switch to Steering Column From Chassis No. ?
1 036M6004 1 Battery
036M0503 1 1 1 1 Battery Clamp Channel, Battery Mounting
XUCS0508 1 1 1 1 Screw, Battery Mounting
036M6005 1 1 1 1 Channel, Battery Mounting
XUCS0532 1 1 1 1 Screw, Battery Mounting
L05W0000 2 2 2 2 Washer, Battery Mounting
XUCB0416 2 Bolt, Battery Terminals
A04W0904 2 Washer, Battery Terminals
AUFN040F 2 Nut, Battery Terminals
2 026M0040 1 1 + Lead, Battery to Earth
026M0041 1 1 + Lead, Battery to Earth
036M0040 1 1 Lead, Battery to Earth
A036M0040 1 1 Lead, Battery to Earth
3 026M0046 1 1 Lead, Battery to Solenoid
036M0046 1 1 Lead, Battery to Solenoid
A036M0046 1 1 Lead, Battery to Solenoid
4 026M0045 1 1 Lead, Solenoid to Starter
036M0045 1 1 Lead, Solenoid to Starter
A036M0045 1 1 Lead, Solenoid to Starter
A036M6313 1 Boot - Solenoid Cable
036M6020 - - - Replaced by 036M6177
5 036M6177 1 1 1 1 1 1 Solenoid Upto Chassis No. ?
036M6299 1 1 Solenoid From Chassis No. ?
PSTS1008 2 Screw, Solenoid to Body
A03W0806 2 Washer, Solenoid to Body
036B6003 2 Nut, Solenoid to Body
6 036M6016 1 1 1 Ignition Coil
036M6142 1 1 1 Ignition Coil From Chassis No. ? to ?
A036M6307 1 1 1 1 Ignition Coil (replaced by 036M6298)
036M6298 1 1 1 1 Ignition Coil (Cold Start)
A036M6416 1 1 1 Resistor
7 036M6248 1 Bracket - Ignition Coil
XUFB1016 1 Bolt
LUFN100F 1 Nut
036M0132 1 1 1 Cable - Cold Start Coil To Solenoid
RSTS1012 2 Screw
036B6003 2 Nut
8 050M6049 1 Suppressor - Coil
9 026M0086 1 Earth Strap - Coil
10 B026M0009 1 1 1 1 1 Distributor - (Weber) Upto Engine No. ?
C026M0009 1 Distributor - (Stromberg) Upto Engine No. ?
D026M0009 1 Distributor - (Stromberg) Upto Engine No. ?
E026M0009 1 Distributor - (Weber), Quick Fit Contacts From Engine No. ?
F026M0009 1 1 Distributor From Engine No. ?
G026M0009 1 Distributor - (Stromberg - Emission), Quick Fit Contacts From Engine No. ?
028M0073 1 Cap
036M6057 1 Brush and Spring
028M0070 1 Rotor Arm
036M6058 1 Contact Set (replaced by A036M6362)
A036M6362 1 Contact Set, Quick Fit Contacts
036M6060 1 Condensor
A026M6097 1 Screw - Distributor to Block
11 026E0740 1 1 1 1 1 1 Ignition Lead Set - Non Emission
B026E0740 1 Ignition Lead Set - Emission
026E0450A 1 Plug Lead (21¼ ins.)
026E0450B 1 Plug Lead (22¼ ins.)
026E0450C 1 Plug Lead (29¼ ins.)
026E0450D 1 Plug Lead (30¼ ins.)
12 026E0451 1 1 1 1 1 1 Coil Lead (13½ ins.)
B026E0451 1 Coil Lead (18½ ins.)
13 026M6001 4 4 4 4 4 Sparklng Plug
A036M6412 4 Sparklng Plug
026M6000 4 Sparklng Plug
14 036M6012 1 Starter Motor, Optional
A036M6338 1 Starter Motor, Optional
036M6180 1 Brush Set
25 2 Bolt, Starter Mounting
120 2 Washer, Starter Mounting
15 036M6212 1 1 1 1 Generator (Positive Earth - Large Mounting Bracket) Upto Chassis No. 7894
036M6250 1 1 1 1 Generator (Positive Earth - Small Mounting Bracket) Upto Chassis No. 7894
036M6306 1 1 1 Generator (Negative Earth) From Chassis No. 7895
16 036M6237 1 Mounting Bracket (Small 6 ins. long)
A036M6237 1 Mounting Bracket (Large 6¾ ins. long)
036M6238 2 Bolt, Mountlng Bracket to Block
036M6239 2 Washer, Mountlng Bracket to Block
036M6240 2 Bolt, Generator to Mounting Bracket
036M6241 2 Nut, Generator to Mounting Bracket
17 026E0030 1 Link - Adjusting
036M6242 1 Bolt, Adjusting Link to Generator
036M6243 1 Washer, Adjusting Link to Generator
036M6244 1 Nut, Adjusting Link to Generator
036M6245 1 Bolt, Adjusting Link to Block
036M6246 1 Washer, Adjusting Link to Block
18 036B1079 1 Horn - High Note, Optional
036B1080 1 Horn - Low Note, Optional
026B0403 2 Spacer - Horn to Body, Optional
19 050M6056 1 Horn Set - Air, Optional
050B1526 1 Mounting Bracket - Air Horns, Optional
026M0039 1 Earth Lead - Engine to Chassis
026M0038 1 Earth Lead - Rack and Pinion
