MA - Electrical - Engine & Horn +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
050M0747 1 + Wiring Loom (replaced by A050M0747)
A050M0747 1 + Wiring Loom - Engine Bay
B050M0747 1 Wiring Loom - Engine Bay
C050M0747 1 1 + Wiring Loom - Engine Bay Upto ?
D050M0747 1 1 + Wiring Loom - Engine Bay From ? to ?
E050M0747 1 1 Wiring Loom - Engine Bay From ?
050M0761 1 1 + Wiring Loom - Engine Bay Upto ?
A050M0761 1 1 + Wiring Loom - Engine Bay From ?
A050M0154 1 + Wiring Loom - Engine Bay From 7001020001N
050M0748 1 Wiring Loom - Facia
A050M0748 1 Wiring Loom - Facia
C050M0748 1 1 + Wiring Loom - Facia Upto ?
D050M0748 1 1 + Wiring Loom - Facia From ?
050M0763 1 1 + Wiring Loom - Facia
A050M0153 1 1 1 Wiring Loom - Facia
050M0749 1 Wiring Loom - Rear (replaced by B050M0749)
A050M0749 1 Wiring Loom - Rear (replaced by B050M0749)
B050M0749 1 1 Wiring Loom - Rear
C050M0749 1 1 Wiring Loom - Rear Upto ?
D050M0749 1 1 Wiring Loom - Rear From ?
A036M0782 1 Wiring Loom - Hazard Warning
050M0750 1 1 Wiring Loom - Front Courtesy Light
050M0742 2 2 Wiring Loom - Door Window Lift
A050M0742 2 2 Wiring Loom - Door Window Lift Upto ? ‘S’ only
036M0790 1 1 1 Wiring Loom - Door Window Lift From ?
050M0052 1 + Wiring Loom - Dipswitch
050M0018 1 1 + Lead - Ammeter to Solenoid
A050M0157 1 1 1 Cable Assembly - bulb Clister
050M0128 1 1 + Lead - Ammeter to Solenoid
050M0132 1 Cable - Cold Start Coil to Solenoid
050M0038 1 1 1 Lead - Earthing, Rack and Pinion
026M0039 1 Lead - Engine Earthing
C026M0714 1 + Cable - Handbrake Warning Lamp (replaced by 050M0716)
050M0716 1 + Cable - Handbrake Warning Lamp
C026M0715 1 + Cable - Handbrake Switch Pad (replaced by 050M0076)
050M0076 1 + Cable - Handbrake Switch Pad
036M6007 6 Clip - Harness
036M6008 8 Clip - Harness
RSTS1008 6 Screw
036B6003 6 Nut
RSTS0608 3 Screw
036B6001 3 Nut
036B6010 2 Clip
RSTS0608 2 Screw
036B6001 2 Nut
036M6011 AR Strip - Perforated
A036M6368 8 Strap - Cables
LWDS0608 2 Screw
442 2 Clip
1 036M6004 1 Battery
036M6005 1 Clamp Channel
XUFS0532 1 Screw
115 1 Washer
050B1207 1 Angle - Battery Retaining
036B6006 2 Rivet
XUFB0416 2 Bolt, Battery Terminals
YUFN040F 2 Nut, Battery Terminals
A04W0904 2 Washer, Battery Terminals
026M0045 1 Cable - Battery to Earth (replaced by 050M0045)
2 050M0045 1 Cable - Battery to Earth (replaced by A050M0045)
A050M0045 1 Cable - Battery to Earth
3 036M0046 1 Cable - Battery to Solenoid (replaced by A036M0046)
A036M0046 1 Cable - Battery to Solenoid
028M0045 1 Cable - Solenoid to Starter (replaced by 036M0045)
4 036M0045 1 Cable - Solenoid to Starter
036M6020 1 Starter Solenoid (replaced by 036M6177)
5 036M6177 1 Starter Solenoid Upto ?
A036M6308 1 Starter Solenoid (replaced by 036M6299)
23 036M6299 1 Starter Solenoid (use with Cold Start Coil) from ?
A050M0132 1 Cable - Solenoid to Coil
RSTS1008 2 Screw, Solenoid to Body
036B6003 2 Nut, Solenoid to Body
A03W0605 2 Washer, Solenoid to Body
6 036M6016 1 Coil (Positive Earth) Upto 1086
036M6142 1 Coil (Negative Earth) - (replaced by 036M6298) From 1087 to ?
A036M6307 1 Coil (Negative Earth) - (replaced by 036M6298)
24 036M6298 1 Coil (Negative Earth) - Cold Start From ?
7 036M6248 1 Coil Bracket
XUFB1016 1 Bolt, Bracket to Coil
LUFN100F 1 Nut, Bracket to Coil
XUFS0416 2 Screw, Coil to Body
A04W0904 2 Washer, Coil to Body
YUFN040F 2 Nut, Coil to Body
A04W1606 2 Washer, Coil to Body
8 050M6049 1 Suppressor - Coil
9 050M6051 1 Earth Strap - Coil
050M6052 1 Earth Strap - Radio
050M6053 1 Earth Strap - Aerial
B036M0009 1 Distributor - Non-Emission (Stromberg) - (replaced by E026M0009), Quick Fit Contacts
E036M0009 1 Distributor - Non-Emission (Stromberg)
10 C026M0009 1 1 1 Distributor - Non-Emission (Weber) - (replaced by F026M0009), Quick Fit Contacts
F026M0009 1 1 1 Distributor - Non-Emission (Weber)
D026M0009 1 1 Distributor - Emission - (replaced by G026M0009), Quick Fit Contacts
G026M0009 1 1 Distributor - Emission
028M0073 1 Cap
036M6057 1 Brush and Spring
028M0070 1 Rotor Arm
036M6058 1 Contact Set (replaced by A036M6362), Quick Fit Contacts
A036M6362 1 Contact Set, Quick Fit Contacts
036M6060 1 Condensor
A026M6097
(20308S7)
1 Screw - Distributor to Block
11 026M0706 1 1 1 Ignition Lead Set (Non-Emission)
B026E0740 1 1 Ignition Lead Set (Emission)
026E0450A 1 Plug Lead (21¼ in.)
026E0450B 1 Plug Lead (22¼ in.)
026E0450C 1 Plug Lead (29¼ in.)
026E0450D 1 Plug Lead (30¼ in.)
12 026E0451 1 1 1 Coil Lead (13½ in.) (Non-Emission)
B026E0451 1 1 Coil Lead (18½ in.) (Emission)
13 A026M6001 4 4 4 Sparking Plug (Non-Emission)
A026M6000 4 4 Sparking Plug (Emission)
A036M6412 4 Sparking Plug
14 036M6012 1 Starter Motor, Optional Upto ?
A036M6338 1 Starter Motor, Optional
25 2 Bolt, Starter Motor
120 2 Washer, Starter Motor
036M6180 1 Brush Set
15 036M6212 1 Generator (Positive Earth) Upto 1086 also installed in: 1089, 1090, 1093, 1095 & 1098
036M6250 1 Generator (Positive Earth)
A036M6306 1 1 Generator (Negative Earth) From 1087 also installed in: 0963-67, 0973, 0981, 1067, 1076 & 1079
A036M6306 1 1 Generator (Negative Earth) From 1593 to ? including 0978, 0982, 0984, 1304, 1310, 1469 & 1470
036M6179 1 Brush Set
036M6236 1 Pulley
036M6232 1 Washer,Pulley to Generator
036M6233 1 Nut,Pulley to Generator
16 036M6237 1 Mounting Bracket
036M6238 2 Bolt, Mounting Bracket to Block
036M6239 2 Washer, Mounting Bracket to Block
036M6240 2 Bolt, Generator to Bracket
036M6241 2 Nut, Generator to Bracket
17 026M0030 1 Adjusting Link
036M6242 1 Bolt, Generator to Link
036M6243 1 Washer, Generator to Link
036M6244 1 Nut, Generator to Link
036M6245 1 Bolt, Link to Block
036M6246 1 Washer, Link to Block
18 050E6001 1 1 + Mounting Bracket - Alternator
A050E0554 1 1 + + Mounting Bracket - Alternator
036M6238 2 2 Bolt, Mounting Bracket to Bolt
036M6239 2 2 Washer, Mounting Bracket to Bolt
19 050M6119 1 1 Alternator
20 050E0030 1 1 + Adjusting Strap
A050E0030 1 1 + + Adjusting Strap
21 050E6004 1 1 + Mounting Strap
A050E0545 1 1 + + Mounting Strap
XUFB0440 1 1 Bolt - Top, Mounting Strap to Cylinder Block
XUFB0532 1 1 Bolt - Middle, Mounting Strap to Cylinder Block
XUFB0444 1 1 Bolt - Bottom, Mounting Strap to Cylinder Block
XUFB0524 1 1 Bolt, Alternator to Mounting Bracket
XUFB0532 1 1 Bolt, Alternator to Mounting Bracket
A05W0905 3 3 Washer, Alternator to Mounting Bracket
YUFN050F 2 2 Nut, Alternator to Mounting Bracket
050M6012 1 Air Horn Kit (replaced by 050M0656)
22 050M6056 1 Air Horn Kit
A050M6160 1 1 Capacitor
