Item | Lotus # | All | +2 | +2 FED | +2S | +2S FED | +2S 130 | RHD | LHD | Description | Change Point Notes Bulletin Reference |
1 | 050L0702 | 1 | Fuel Tank | ||||||||
A036L0047 | 1 | Seal - Fuel Tank to Body | |||||||||
W0210 | 1 | Rubber Seal - Fuel Tank to Body | |||||||||
2 | 050L0037 | 2 | Strap - Fuel Tank Retaining | ||||||||
3 | 050L6005 | 2 | Rubber Strap - Fuel Tank Mounting | ||||||||
XUFS0412 | 6 | Screw, Retaining Straps to Body | |||||||||
YUFN040F | 6 | Nut, Retaining Straps to Body | |||||||||
A04W1606 | 6 | Washer, Retaining Straps to Body | |||||||||
AUFN040F | 2 | Nut, Retaining Straps Tensioning | |||||||||
L04W0000 | 2 | Washer, Retaining Straps Tensioning | |||||||||
4 | 050L6000 | 1 | Sender Unit - Fuel Gauge | ||||||||
050L6001 | 1 | Gasket - Fuel Gauge Sender Unit | |||||||||
050L0705 | 1 | Filler Neck Assembly (replaced by 050L0705A) | |||||||||
5 | 050L0705A | 1 | Filler Neck Assembly | ||||||||
050L6008 | 1 | Secondary Seal | |||||||||
050L6011 | 1 | Anti-Splash Assembly | |||||||||
050L6001 | 1 | Gasket - Filler Cap (replaced by 050L6009) | Bulletin: Service 1970/9 |
050L6009 | 1 | Gasket - Filler Cap | |||||||||
050B0328 | 1 | Grommet - Filler Neck to Body | |||||||||
050B1440 | 1 | Support Bracket - Filler Neck | |||||||||
6 | 050L6007 | 1 | Hose - Fuel Filler Neck, Optional | ||||||||
050L0003 | 1 | Hose - Fuel Filler Neck, Optional | |||||||||
7 | 036L6002 | 2 | Hose Clip | ||||||||
8 | 050L0038 | 2 | Breather Hose | ||||||||
9 | 036B6010 | 6 | Grommet - Breather Hose to Body | From Chassis No. 0994 | |||||||
10 | 050L0006 | 1 | Pipe - Fuel Tank to Pump | ||||||||
11 | 050L6003 | 1 | Bolt - Banjo, Pipe to Chassis | ||||||||
12 | 050L6004 | 2 | Seal - Bolt, Pipe to Chassis | ||||||||
036L6003 | 2 | Fastener, Pipe to Chassis | |||||||||
036L6004 | 2 | Grommet, Pipe to Chassis | |||||||||
13 | B026L0703 | 1 | Fuel Pipe - Pump to Carburetters (Weber) | ||||||||
14 | 026S0132 | 1 | 1 | 1 | 1 | ‘T’ Piece, Pump to Carburetters (Stromberg) | |||||
15 | 026S0133 | 3 | 3 | Clip, Pump to Carburetters (Stromberg) | |||||||
15 | 026S0133 | 2 | 2 | Clip, Pump to Carburetters (Stromberg) | |||||||
16 | D026L0703 | 1 | 1 | 1 | 1 | Fuel Pipe, Pump to Carburetters (Stromberg) | |||||
17 | 050L0040 | 1 | Fuel Tank | 1971 Evaporative Loss Control | |||||||
18 | 050L6013 | 1 | Filler Cap | 1971 Evaporative Loss Control | |||||||
19 | A050L0045 | 1 | Filler Neck | 1971 Evaporative Loss Control | |||||||
20 | A050L0073 | 1 | Pipe - Vent | 1971 Evaporative Loss Control | |||||||
21 | 050P6002 | 2 | Clip - Pipe | 1971 Evaporative Loss Control | |||||||
22 | A050L0075 | 1 | Hose - Filler Neck | 1971 Evaporative Loss Control | |||||||
23 | 050L0039 | 1 | Catch Tank | 1971 Evaporative Loss Control | |||||||
24 | A050L0066 | 1 | Pipe - Fuel Tank to Catch Tank | 1971 Evaporative Loss Control | |||||||
25 | A036L0063 | 1 | Pipe - Catch Tank to Main Pipe | 1971 Evaporative Loss Control | |||||||
26 | A050L0072 | 1 | Pipe - Main Fuel Feed | 1971 Evaporative Loss Control | |||||||
27 | 036L6004 | 3 | Grommet | 1971 Evaporative Loss Control | |||||||
28 | A050L0068 | 1 | Pipe - Main Pipe to Canister | 1971 Evaporative Loss Control | |||||||
29 | 036J0135 | 4 | Elbow | 1971 Evaporative Loss Control | |||||||
30 | 036L0046 | 1 | Canister | 1971 Evaporative Loss Control | |||||||
31 | A050L0069 | 1 | Pipe - Canister to Airbox | 1971 Evaporative Loss Control | |||||||
32 | A050L0070 | 1 | Tube | 1971 Evaporative Loss Control | |||||||
33 | A050L6014 | 1 | Pipe - Canister to Carburetters | 1971 Evaporative Loss Control |
