Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
028J0714 | - | Replaced by 036J6085 together with: 1 off J6055 Hose 1 off 036J6083 Hose 1 off 036J6081 Bundy |
Upto Chassis No. 9234 | ||||||||||
1 | 036J6085 | 1 | Servo Unit | From Chassis No. 9325 | |||||||||
2 | 036J6054 | 1 | Mounting Bracket - Servo | ||||||||||
XUFS0612 | 3 | Bolt, Servo Mounting Bracket | |||||||||||
L06W0000 | 3 | Washer, Servo Mounting Bracket | |||||||||||
036J0089 | 1 | Backig Plate | |||||||||||
XUFS0412 | 4 | Bolt, Backing Plate to Mounting Bracket | |||||||||||
106 | 4 | Washer, Backing Plate to Mounting Bracket | |||||||||||
3 | 0506055 | 1 | Hose - Vacuum - Servo to Bundy | ||||||||||
4 | 036J6081 | 1 | Bundy Pipe - Vacuum | From Chassis No. 9325 | |||||||||
5 | 026J6091 | 1 | Bundy Pipe - Vacuum - Servo to Non-Return Valve | Upto Chassis No. ? | |||||||||
6 | 036J6083 | 1 | Hose - Vacuum | From Chassis No. ? | |||||||||
7 | 026J6093 | 1 | Hose - Vacuum | Upto Chassis No. ? | |||||||||
8 | 050J6019 | 1 | Non-Return Valve | ||||||||||
9 | 026E0367 | 1 | Union - Vacuum Connection | ||||||||||
10 | 036J6068 | 1 | Connector - Vacuum | ||||||||||
054J6028 | 2 | Clip - Vacuum Hose | |||||||||||
036B6010 | 1 | Grommet - Pipe to Chassis |
