JD - Brakes - Master Cylinder +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
1 050J6005 1 1 1 Master Cylinder
2 036Q6020 1 1 1 Push Rod - CylindeExtensionr
3 050J6032 1 1 1 Extension
4 050J6006 1 1 1 Cap
5 050J6070 1 1 ‘Sovy’ Device
050J6031 AR AR AR Repair Kit - Master Cylinder
050J6036 1 1 1 Clevis Pin, Pedal to Master Cylinder
050J6037 1 1 1 Cotter Pin, Pedal to Master Cylinder
7 050J6040 1 1 tandem Master Cylinder
8 050J6042 1 1 Push Rod
10 050J6066 1 1 Cap - Master Cylinder
050J6041 AR AR Repair Kit - Tandem Cylinder
11 050J6053 1 1 Pressure Differential Warning Valve
