Intro - Vehicle Chassis Numbers and Part Numbers
INTRODUCTION
This publication contains all assemblies and parts sold as spares; it enables one to determine with precision their Part Numbers and to identify them from the illustrations.
The method of identifying a vehicle, whether Component-Built or Fully-Built, is by use of the Vehicle Chassis Number which is comprised of code numbers as shown below. The Vehicle Chassis Number will be found stamped on a plate which is fixed to the left-hand side of the engine bulkhead.
36/01234
‘36’ = Vehicle Type = Elan Series 3
‘01234’ = Chassis Number
Part Numbers - All Part Numbers commence with the Vehicle Type Number which enables one to determine if the part is peculiar to the Europa or whether it was first used for some other Lotus ‘road’ vehicle, thus: -
  • 46, 54 = First used on Europa
  • 26, 36, 45, 500 = First used on Elan
  • 50 = First used on Elan + 2
Standard Hardware Part Numbers - All standard finish Bolts, Screws, Studs, Nuts and Washers carry Part Numbers in accordance with the code given on page 9.
Type change points:
S1 from: October 1962 Chassis No. 26/0001 to 26/3899
S2 from: Autumn 1964 Chassis No. 26/3900 to 26/5810
S3 from May 1966 Chassis No. 36-45/5811 to 7399
S3 ‘Super Safety’ from: November 1967 Chassis No. 36-45/7400 to 7894
S4 from: March 1968 Chassis No. 36-45/7895
S4 ‘Sprint’ from: January 1971
The designations ‘LEFT’ and ‘RIGHT’ are to be understood as seen in the driving direction.
Indented parts in the ‘DESCRIPTION’ column are incorporated in the preceding - not indented - part. The term ‘optional’ in the ‘DESCRIPTION’ column indicates that the respective parts will be supplied as available or in the case of repair sizes as requested.
If required, ‘CHANGE POINTS’, (i.e. CHASSIS, BODY or ENGINE Nos.) will be indicated in full in the ‘CHANGE POINT’ column.
If a part is applicable to all models or versions, the quantity is listed in the column ‘ALL’, but if a part is particular to a model or version then the quantity will be listed in the column of the models and the version indicated thus ‘+’ in the respective column.
If a ‘quantity per model’ variance occurs the quantity will be indicated in the respective model or version.
All parts do not necessarily correspond to the illustrations.
All Lotus Parts Numbers are being ‘updated’ to contain a maximum of nine (9) digits.
Example:
  • Part Number A46 B 040 becomes A046 B 0040
  • Part Number A46 A 709 becomes A046 A 0709
  • Part Number 54 B 6000 becomes 054 B 6000
When reading the text figure numbers will be shown against the illustrated side or hand.
Instructions on Ordering
  1. Ascertain the exact model for which parts are required and obtain the chassis and engine numbers.
  2. Refer to Pictorial Index Plate (page 10) and select Section(s) for which Part(s) are required.
  3. Study the illustration and select Plate Reference Number(s).
  4. Relate the Plate Reference Number to the Plate Reference Number of the Parts List text.
  5. To select the exact part number of the Part(s) required,
    a. read the ‘QUANTITY’ column using the model variant if applicable.
    b. read the ‘DESCRIPTION’ column for correct order identification.
    c. check the ‘CHANGE POINT’ column for any further information relating to the series or model type.
    d. recheck the part number(s) selected, repeating instructions 3 to 5c inclusive.
Examples:
Elan ‘S3’ Chassis No. 36/6400.
Part Required: Bonnet Lid.
Section B Plate BB Plate Reference No. BB9
Supply Part No. 026 B 0030 if stocks available, if stocks are exhausted supply Part No. C026 B 0030 (with power bulge).
Elan ‘S4’ Chassis No. 45/8190.
Part Required: Speedometer k.p.h.
Section M Plate MK Plate Reference No. MK 1.
Supply Part No. A036 M 6103.
As from January, 1970 vehicle identification will be in the following form: -
      7001.010001A	Both chassis and body numbers being the same.
      7001.		Represents year and month of manufacture.
           01	Represents the production batch.
             0001	Represents the unit (chassis) number.
                 A 	Represents the model code.
As there are sixteen different model types within our present production control, the following codes will be used for correct model identification: -
Elan Standard Fixed Head Great Britain & Northern Ireland A
Elan Standard Fixed Head Export B
Elan Standard Drop Head Great Britain & Northern Ireland C
Elan Standard Drop Head Export D
Elan Special Equip. Fixed Head Great Britain & Northern Ireland E
Elan Special Equip. Fixed Head Export F
Elan Special Equip. Drop Head Great Britain & Northern Ireland G
Elan Special Equip. Drop Head Export H
Elan Federal Fixed Head Export J
Elan Federal Drop Head Export K
Elan + 2 ‘S’ Type Great Britain & Northern Ireland L
Elan ÷ 2 ‘S’ Type Export M
Elan + 2 ‘S’ Type Federal Export N
Europa Standard Great Britain & Northern Ireland P
Europa Standard Export Q
Europa Federal Export R
