Installing and torquing crankshaft pulley
Well, I got the crankshaft pulley off with the engine in place and the radiator removed. All good. Thanks for the tips in this earlier thread.
viewtopic.php?f=39&t=53547
I now need to install the new pulley with the 36-1 teeth for a crank position sensor… How do I go about this? Do I insert the key and somehow press the pulley on? I tried offering it up but it is hanging up on the key. How do I get it started? Is it expected to have to file the key a bit?
I have seen reference online to inserting a longer bolt with a nut on it into the crankshaft, and gradually tightening the nut to seat the pulley? Or the use of a longer bolt with a stack of washers to gradually tighten the bolt and seat the pulley?
Basically my problem is my air impact driver is not tightening up, and if I use a conventional socket wrench the engine is spinning as I don’t seem to have a reliable way to lock the engine or rear wheels with it in gear? The required torque is quite modest, like 24 to 28 ft lb, so should be some way to keep everything from turning. Thinking I should use Locktite medium perhaps? I suspect something was used originally as it was difficult to remove.
Any help appreciated. Real rookie at doing something like this, and mainly focused on not screwing something up.
Stu
As with when you raised it previously and some people said you needed a puller to remove the pulley and others said you didn’t the key considerations are mechanical sympathy and common sense. If you feel a need to force things STOP AND THINK. I’d suggest you are at that point with this. Using an impact gun capable of up to 1200Nm of torque to try and force the pulley on is not exhibiting mechanical sympathy.
Best to take it apart again and compare new part versus old part to find out why there is a problem
The key sits in both the chain sprocket and the crank pulley.a gentle tap on the front edge may seat it a little lower at the front enabling the pullet to go on. Make sure there are no burrs on the key or the new pulley and check the pulley bore versus the crank nose diameter as the pully should be a smooth hand push fit. never trust the dimensions of replacement parts to be accurate
With the engine in gear and the rear wheels on the ground you should be able to tighten the bolt to the required torque.
After having checked for burrs, sizing etc., I would offer up the new pulley without the key in place to see what the fit is like. When satisfied, fit the key, making sure that it is properly seated, and with the front tip of the key fractionally lower than the back. That way, the key wont butt up against advancing pulley. And before final fitting of the key and pulley, put a smear of grease on the whole of the crank nose and inside the pulley. It will stop them bonding together with rust. Works for me.
Good luck.
Leslie
It can be difficult locking the engine up by putting the transmission in gear because the dampening springs in the clutch plate will make the locking effect feel squishy rather than firm. It’s easy though and well worth a try first. Another easy way to lock the engine is to remove the cam cover and poke something solid through the spokes in a camshaft drive gear and rotate the engine until that something solid contacts the head. I prefer to use a soft copper or brass rod rather than a screwdriver for the “something solid”. You could try locking the flywheel via the ring gear with something solid also. You can access the ring gear by removing the inspection plate / cover or starter motor.
I use medium loctite on that bolt because I have known it to become loose despite being torqued to the correct figure.
I wouldn’t be applying torque through the cam chain if I were you.
Locking the flywheel is the better option.
In addition to 512BB’s advice try the key in the pulley. It should be a sliding fit.
Agree with JonB. That’s a stupid idea.
Locking at the cam has worked for me. 28Nm isn’t a lot of torque but obviously if you are going to use more than that use some common sense. Fine to use a rattle gun to undo the bolt (in which case you won’t need to lock anything) but certainly don’t use it to tighten it up. Yes locking the flywheel is the best method but it is more difficult.
Thanks for the tips. Got it installed and torqued. Excellent point on the clutch springs making everything feel spongy.
After I oiled everything up and cleaned up the woodruff key I gave it another try. After finally getting the key properly positioned with ever so slightly sloping downward I was able to line up the key way on the first try! A dab of grease helps to retain the key in the pocket to get it positioned.
The torque wrench clicked just as the rear tires were slipping. Perfect. I think part of my problem is the garage floor can be pretty slippery.
Stu
Not much mechanical sympathy there, IMHO. Much better to jam the flywheel starter gear, as you also suggested.
Malcolm
Locking at the cam has worked for me. 28Nm isn’t a lot of torque but obviously if you are going to use more than that use some common sense. Fine to use a rattle gun to undo the bolt (in which case you won’t need to lock anything) but certainly don’t use it to tighten it up. Yes locking the flywheel is the best method but it is more difficult.[/quote
It may have worked for you, but it’s just the wrong thing to do for so many reasons. If you are going to the extent of fitting crank triggered programmed ignition/full engine management, removing either the lower dirt plate or the starter to lock the engine properly while torquing up the crank bolt is not that big a deal.
What was the crank position sensor/wheel combo that you bought? Also I am curious about what ECU you will use. I am planning to do something similar once my Zetec car is running…
All the best
Berni
“works for me” is the key word here “works for you” can be something entirely different. It’s still a democracy hopefully. To me fitting things like CV joints when the vehicle wasn’t originally designed for them, aluminium flywheels, stainless steel brake pistons etc. could be wrong for quite a few reasons. The facts are however that people have fitted these things and it’s worked for them so that’s what is important. It’s not me who is driving your car after all.
With something like this at least if you break something it will be immediately obvious where as with some other things it may only happen after a considerable period of use and fatigue cycles.
I’ll say one thing though. You must be a very lucky guy to have a partner who is willing to crawl under your car and lock the flywheel with a screwdriver whilst you muck around with the crankshaft pulley bolt (assuming you haven’t made a special fixture to do the job). Be sure to give your partner something special for Valentine’s Day! - maybe one of those made up tools.
I am a very lucky guy. I have a group of friends who all have various old cars. One guy has two type 14 Elites, one guy has a Clan Crusader, a 1967 Mini, a pre war MG and a nicely rebuilt mint TR6. Another has a Chevette historic rally car and a TVR Griffith… Yet another has two eighties 911s. I’m the poor relation with just an Elan…and we help one another out whenever necessary. My wife has no interest in cars apart from trips out on the sunshine: she won’t be under the car any time soon. She’ll still get something nice for Valentine’s Day though as unlike some guys partners she doesn’t mind what I spend on the car!
I wouldn’t say you were the poor relation just because you have an Elan because anything Lotus of course speaks of innovative engineering and racing pedigree.
As for women my test used to be to keep an engine block strategically placed in the lounge room as a trip hazard. When the target candidate stumbled over the engine block the outcomes arising from the incident provided useful material to assess whether the relationship was going to be of a long term nature or not. I guess this is another example of something that worked for me that may not work for you. But who cares. It’s a democracy.
I’m puzzled as to why you didn’t simply engage the handbrake and put the car in top-gear?
I don’t think I’ve ever had problems putting the crankshaft pulley on and I usually remove it when fitting a new sump gasket in that area.
Hi Bernie
I got the sensor mount and pulley from QED. They are in the links below:
qedmotorsport.co.uk/product/cra … -36-teeth/
qedmotorsport.co.uk/product/cra … g-bracket/
They also list the compatible Ford sensor, although I got mine from the ECU supplier instead.
qedmotorsport.co.uk/product/cra … ford-type/
I am going with the ignition only version of Motorsports-Electronics ECU called the Nodiz Gen-X.
motorsport-electronics.co.uk/pr … c-harness/
The Nodiz Gen-X seems to be a relatively new model. I believe the programming software is now similar to their fuel injection products, rather than earlier versions with mode buttons and some flashing LED’s. The box is water resistant and rugged looking, although still debating whether to mount it under the bonnet or in the interior.
The system will also use a throttle position sensor. I am using this one, which was a very complete & simple screw on kit. You do need to add the matching connector & boot to make up a short loom run to the main Nodiz connector, or specify this loom leg when you purchase the complete deal from ME.
webcon.co.uk/products/9948- … 4045-dcoe/
For simplicity of installation I have opted to not use the other features included in the ignition only ECU, including coolant temperature and cooling fan control. I am happy with my already installed Clivey Boy fan controller.
Next on the list is to finish off the loom and unit mounting. I plan to test fire the engine before removing the dizzy. Once I am confident it functions OK I plan to permanently mount the Ford coil pack over top of the dizzy blanking plug; I got one one on eBay that looks a bit better than the QED offering. I am also using a coil pack mounting bracket from TriggerWheels.com, but that still needs some MacGyvering. The idea is the engine can easily be pulled by simply disconnecting the coil pack, TPS, and CPS at their respective sealed connectors and leaving the coil pack and wires in place.
Basically the plan is to retain my new style Weber 45’s but get better ignition performance. I am particularly wanting more advance at highway cruising speed with very small throttle openings. Struggling to get smooth engine performance and reasonable fuel economy without vacuum advance.
Once I get the Nodiz working I am hoping to do up a more complete thread on how it works and so forth. Although the ECU is preloaded with a suitable ignition curve the system will require one time only programming to set the position of the missing tooth relative to TDC. Other than the three connections to the engine, the only other wiring required is a four way connector with ground, pure clean 12v power supply, ignition trigger wire, and tach signal output, so the whole thing is really quite simple and slimmed down.
Anyway, I got the trigger wheel mounted and a very nice consistent gap to the sensor, although I had to bend the mount slightly. The QED mount included three 1 1/4” hex head cap screws, but I separately purchased longer socket head screws to stay consistent with the other oil pan fasteners. Hopefully I haven’t created a pan leak.
I am presently waiting on a correct fan belt, which has to be installed before the sensor is buttoned up for the final time.
Bill, I didn’t know my Plus 2 has a handbrake. Always wondered what that deal is for. :smiley:
Cheers guys. Thanks again for the help. Keep buggering on!
Electrical / electronics generally don’t like heat and vibration. Depending on the Ford coil pack you use, it was likely mounted on an inner wing or firewall in its original fitment. Not sure how happy it will be bolted to the engine. There have been others on here who have gone for the ‘coil pack over the dizzy hole’ route, so perhaps they can comment whether they suffered with reliability issues.
Modern coil over plug arrangements obviously suffer from both heat and vibration - but they are supposedly designed for it - although I have just had to replace 2 on my son’s Mini.
Actually most Ford Zetec engines have the coil pack mounted on a bracket attached to the cylinder head above the gearbox…and that’s the usual one that’s used for this application.
Hi Stu,
You made a great choice with the Nodiz Pro Gen-X. I installed exactly the same combination of TPS, Pulley, Sensor, Coil Pack on my Twincam as described in this https://lotuselan.net/forums/viewtopic.php?f=31&t=47916 forum thread. Only difference I can see is that I am using 40 DCOEs.
Couple of things to consider:
-Motorsport Electronics https://motorsport-electronics.co.uk/ provide excellent customer support. Whenever I needed help, they responded immediately and with useful advice.
-I sympathise with the comments about coil pack location / vibration etc, but to date have had no problems.
-The new CPS sensor mounting bracket makes it a challenge to mount a degree wheel between the new QED pulley and the chassis cross-member if you need to check your cam timing. I ended up building a custom degree wheel assembly on top of the old cast iron crank pulley, and fitting it whenever I wanted to adjust the cams (I have ‘vernier’ pulleys fitted and like to tinker)
-I did fit water and air temperature sensors. The water temperature sensor was very useful in revealing that my standard gauge was reading way too low. It is being serviced now by Caerbont https://www.smiths-instruments.co.uk/ and hopefully will be closer match when it comes back.
-The air temperature sensor was unnecessary and, with the excellent help of Motorsport Electronics I have repurposed the 0-5V analogue input on the Nodiz unit to read instead the 0-5V output from my AEM AFR sensor. Together with the Rev and TPS it means I can generate a mixture plot (obsolete example below) to guide my tinkering with carb jets.
The result of all this? I have a twincam which even with 420 cams will idle smoothly down to 650 rpm if asked to, starts on first turn, is tractable in city traffic, and pulls strongly all the way up.
If you feel I can help with anything, feel free to get in touch
