?How to replace your input differential oil seal without removing the Diff from your Car?
I am sure that there are many of you that have carried out this work in the parts and will fully understand what I am about to describe ? This is for those who haven?t.
I posted the above question some weeks ago and was told that the only way to replace it would be to remove the diff from the car ? Well knowing this would be like extracting teeth from a lion I decided to leave the diff where it was and give it a go.
Obviously the first thing to do is remove the oil from the diff ? Sounds easy! Well when you can not turn the nut round because its been over tightened then you hit your first problem.
So I jacked the car up at the back and put it on axle stands knowing when I removed the input shaft I would get covered in oil!! Never mind.
The next thing to do is remove the 4 nuts/bolts holding the prop-shaft to the input flange making sure you mark both flanges so that it goes back the same way ? Not sure this is important as they are not balanced as an assembly.
The next thing to do is part the two flanges and then (using half a brick) support the prop-shaft so that it is as high as it can be (the brick should sit on the chassis under the prop-shaft).
The next problem you come across is that you can not see the diff nut and if you could you can not get a spanner onto it!! This is where my dad?s old set of sockets can into its own.
From memory the nut is 15/16th and there is no room to attach a ratchet to it once it is on the nut.
My dad?s socket set had the old type of ratchet, that has the center drive which pushes out either side of the ratchet to change the rotation. Remove this from the ratchet, place it in the socket and then get a small spanner that fits the square drive.
With this you should be in a position to place the socket/boss onto the nut and then undo it!!
Once removed you are then in a position to remove the input flange/shaft. It is at this point your hand, sleeve and arm gets covered in oil. After mopping up the mess the next thing to do is pull out the shaft ? It is at this point you realize that the shaft will not come out as it fouls the prop-shaft ? Oh what joy!!
The next thing to do is unbolt the prop differential torque tie rods from the chassis and pull the bars from the thread (or remove the bolt) so that they are totally free. This will then allow the diff to move on its upper rubber mounts.
You can then either pull the diff down or put a block/wedge above it or use a rope to pull the front end of the diff down.
This will then give you enough space to remove it completely.
Hurrah!!
The next thing to do is remove the old oil seal. Using a suitable length screwdriver, place it in at an angle so that it is behind the seal and then leaver it out.
Clean off the seal surface area and replace the seal with a new one ensuring that it is flush fitting, then reassemble the diff/prop-shaft - Don’t forget to put new oil in the diff - Now theres another story!!!
From start to finish it took me 3 to 4 hours to complete, however this involved a great deal of time considering the issues and coming up with a way around the problem.
Also there were the odd coffee breaks, getting the ball out of the tree for the kids and answering the phone; so you should be able to complete the above in 1to 1? hours without any complications ? What are they I hear you shout.
Looking at the old seal it would appear that time, heat and oil had taken its toll on the seal and after replacing it I have seen no further leaks
I hope this is of assistance and good luck.
