Hey gang:
Had everything going well on my rebuit engine. then, one day, after not driving for a week, the car’s starting characteristics seemed odd. Took a tone of pedal pressed down to get enough fuel to get idle. Then, once it got warm enough to actually stay running, the off-idle hesitation was massive under load. And, once it gets going to 4-6000 rpm, nowhere near maximum power output.
Seems like fuel starvation, right?
Nothing else was changed in the interim, so I’m wondering about the following possibilities in this order of likelihood?
bad fuel pump (most likely?)
stuck valves. (Unlikely, since the rebuild is new?)
some air passageway blockage (could it be this bad?)
plugs? I checked, and also got the carbs synched up at least tolerably once it was running.
Do these symptoms sounds familiar to anyone?
thanks as always.
Jeff
