Homemade Bonnet Prop Rod
Here is something I made that is a lot more convenient that a broomstick. It is made of 1/4" dia HRS, a spring, a short piece of tubing, and a rubber grommet.
I originally wanted to make it so I wouldn’t have to drill any holes, but there was no convenient place in the body, so I did have to drill one hole in the inner fender for the rubber grommet (similar to the early Europa). If putting holes in fiberglass doesn’t bother you, you could make it much simpler by putting another grommet in the bonnet and doing away with the latch mechanism.
To slot the latch tubing, I used a milling machine, but a dremel tool might also work. I welded the small sleeve to the rod, but you could also drill through for a small pin, etc.
This works with no front spring installed, but I wouldn’t trust it in any kind of strong wind.
Tom
Quite neat Tom :slight_smile:
I can’t help thinking it’s easier to remove the bonnet completely … :question:
Well, usually so, and a lot better access, but when you just want to check the oil and there is only rough pavement at the gas station, I think it will come in handy. Plus I won’t have to reattach the front spring each time.
I guess it is all what you are used to.
Tom
I too either remove the bonnet for ‘surgery’, or use my shoulder as a prop if it’s just a ‘check up’ - however, my T-shirt sleeves get dirtier as the underside of the bonnet gets cleaner… :wink:
:arrow_right: Matthew
my home made prop – :laughing: --also good for road rage abatement --ed
blunt end
round end [with hole] for wall hanging when it was attached to an Italian banjo—ed
