Heater foot vents
Yep another quandry I need help with.
I have now got the white over handles that go to open the heater vents for the feet.
I thought that this would be the end of it, but noooo!
There must be something that the white handles fasten over, but I have no reference as to what it is! Can anyone give me any photos of what it is that I am looking for? Or better yet sell me a pair?
Jason
Hi Jason,
Is this what you are looking for ?
Not quite,
It could be that my heater is not correct, but it does seem to fit otherwise.
The white handles just under the blue cable must fit over something. That is the part I am missing, whatever the white handles fit over.
The pic shows the underside of the bracket you are missing which looks like a simple T shape spot welded to the flap. The handle is retained by one screw and the function of the bracket is just to stop it rotating. Shouldn’t be difficult to make something up to do the job and either epoxy bond it to the flap or secure it using the screw that fixes the handle. Alternatively you could bond something into the handle itself which engages with the slot in the flap to do the same job.
Or are you looking for something that the white handle would snap onto to hold the flap in the closed position???
I have been back to mine & looked at the picture again.
I am missing 2 things! Freather has hit the nail on the head (twice actually)
I have the spot welded “T” it come through the flap and ends in 2 delicate rings that “the white handle would snap onto”
“to hold the flap in the closed position” made me question my set up again.
I don’t have any of the spring / braketry either. I assume that the screw the holds the brakets to the flap also fastens the handles to the flaps
Jason
If no-one solves your problem, I’ll take a look at mine (after a couple of days vacation - sorry).
Jason,
I know these flaps were used on many variants of Smiths heater systems of the day. One I know is the old LR Defender - so I found this:
cgi.ebay.co.uk/LANDROVER-HEATER- … 286.c0.m14
I seem to remember that the old Mini had something similar - but the memory is not what it was.
Why not contact Smiths in an attempt to find someone in their engineering offfice that may be interested enough to help?
Jason,
The picture on the “oldelanman” post showed the secret. The hairpin spring that holds the flap open also holds it closed. It’s an interaction between the spring and the lever arm that it’s attached to. There’s no clasp or tab to hold the flap in the closed position.
It’s fortunate that I got my engine reattached to the chassis today so that I could move the framework that I use because I’m too cheap to buy an engine hoist :smiley:
Hi I make the heater outlet door, and the heater motor, heater unit, heater rad, heater valve, and have the heater duct in stock
let me know if I cam help you with heater parts tel 01372 456304 work day time number
ebay.co.uk/itm/LAND-ROVER-SE … 43d2041b21
my face book page facebook.com/pages/Ashley-H … 05?fref=ts
Regards Ashley Hinton
