On a recent drive out a problem occurred with no heat from the heater on my sprint, It just blew cold air wether the valve was open or closed I am thinking airlock.Any thoughts as to rectify the problem would be greatly appreciated.
Sounds like an airlock, so as a first thought, try closing the heater valve, disconnect the pipe going to the heater matrix and remove the rad cap. Next fill the disconnected pipe with water and see if you can blow down the pipe to see if the water level in the radiator rises, if so try filling the pipe some more and blow again. Hopefully if it is an airlock you may be able to blow it through. Use a G clamp or similar across the pipe so water does not escape when you reconnect the pipe to heater valve.
Let us know how you get on so others can chip in with suggestions if the above does not solve the problem.
Tony
Had a look at the Elan today and did what was suggested although seems a bit more heat but its still not right
I have no radio fitted so I could get my hands inside to check the input pipe to the heater matrix very hot but on the output pipe only Luke warm , could the matrix be blocked plugged. Also the pressure coming out of the heater valve did not seem that strong when opened fully but I could not run the engine with the pipe of that for obvious reasons
The return pipe to the engine pump side is only Luke warm even after a run out so I’m thinking matrix has some kind of restriction.
I will try to blow pressure from the output side to see if anything has blocked the input side into the matrix
Yes. Don’t overpressurise it with an airline. Easy to damage.
I’d flush with water via a garden hose. First in the direction of flow, then backwards flow if you get my drift. You might also try soaking it in a flushing solution to loosen any crud, or descaler.
If the blowing fails try using a radiator flush product keeping the heater valve wide open, however be a little careful if you try blowing with this liquid in the system as you don’t want to be swallowing any of it.
Take the car for a run till its nice and hot, then leave overnight to try and break down any sludge that has accumulated, then run it again before finally draining and refilling the system. From memory you can leave the product in the car for a while but check on the product container to verify
Tony
Ive flushed the matrix both ways and I took the car for a drive.Initially the thing seemed to be ok and heat was coming through vents and the input output pipes were hot.Then after about 10 miles back to square one no heat again
So back home I flushed again with a bit of air pressure from the output side.i noticed a lot of brown dirty water emerged. seemed odd as I’m running bluecol.Anyway flushed again until clear water running both ways without any restriction.
Im hoping this has cured it.Out for another run on next decent day.I will update then
Yes the radiator is hot and the fan cuts in and out
It seems as though the water from the heater matrix is not being allowed back to Main flow
When I take rad cap off the water is returning via thermostat to top of rad so I know the thermostat is ok.I took that out and checked that it was ok
the only thing I can suggest is the capillary tubes in the matrix are blocking
Something in there is not rt as the out feed pipe is cool I feed pipe is hot
Was strange on the last run it seemed ok for a while then went cold again
When you first start the engine the hose to the Rad should stay cold and only hose to Heater heat up.
As said the Heater Valves are not that good and the Diaphragm might be in bits blocking circulation.
I will check out the valve to make sure it’s ok in fact I will take it off and run direct that will tell me if its a faulty valve or there is a restriction in the matrix.
It’s for American Motors & International Harvester vehicles of the mid-1960s and both spigots are exactly the right size to use in an Elan or Plus 2. 90-Degree valve operation, turns easily, been meaning to attach a cable to I can operate it from inside the car. Was under $30 but I forget where I bought it.
I removed the heater valve and found it to be partially blocked I then piped the system direct and the heater is now red hot
A new heater valve is sort.As these things are not reliable I might look at the valve in the last post.If it has to come from the States I may overlook it and get another of the same origin.
As these are probably made in China its pot luck on the quality of the product. If anyone knows a better product let me know.
The valve listed has a NPT thread while the Twincam head has a BSP thread ? There is one with inline hose barbs rather tthan hreaded on end which may be an option
You know, that hadn’t crossed my mind at the time. But because the thread is tapered I used plenty of tape on it and it seemed to go in smoothly and securely and has held perfectly ever since.
I wonder though, from the look of it, I suspect that the threaded part could in theory be removed and a BSP-fitting brazed on, maybe.
