Heater access
Is it possible to get at the heater controls at the heater end without removing the dash entirely?
Just hoping…
depends what you need to do. You get some access by removing the radio.
best regards, iain
Thanks Iain,
I need to adjust the control that opens/closes the heat flap as I can’t get the heater unit to blow cold. Also may have to access the vent tubes as one of the eyeball vents doesn’t work and the output from the demisters is pitiful…
There is a clamp around the outer of the cable behind the control. You may just get to that through the radio hole. Access to to the other end is behind the left-hand footwell trim. No guarantees, but worth a try before you move the dash.
good luck.
Iain
Thanks again Iain, I’ll give it a go :smiley:
