soted it out now, made my own after a lotus dealer tried charging ?70 for one!!!
When did you have the problem,I’ve got a couple in the shed from when i fitted a glass sunroof
Hi john,
Well i decided not to pay the ?70 so i went and bought some 5/16" fuel line hose (nickel stuff) and bent it into the shape and length required. Hopefully it will be ok, however it is not quite as rigid as the original ones which seem to be in mild steel. If you really dont need them it would be a help incase my ‘home made ones’ arent up to the job.
What would you like for them,and where abouts in the country are you.
thanks
Simon
Simon
I’m in Glossop,a couple of quid should do the job,going to Stoneleigh later this year,where are you?
