head light relais connection
can anyone help me explaining the following: in the wiring diagram the relais have 4 connections: c1 c2 w1 and w2.
My Hella relais shows 30 85 86 and 87. Does anyone know how I connect this??
Have tried it but relais makes strange noise so something is not right.
I am frustrated cause can not drive the car and spring has arrived!
Robin
The connections in some applications are swapped with corresponding terminals but this should be O.K. for your car.
Many thanks Brian for this info, I will keep this with the wiring diagram and will connect the relais accordingly.
Robin
