HB - Steering - Column +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
050H0705 1 + Column Assembly Upto Chassis No. 0928
050H0706 1 + Column Assembly Upto Chassis No. 0928
026H0705 1 1 1 1 + Column Assembly, Without Lock From Chassis No. 0929
026H0706 1 1 1 1 + Column Assembly, Without Lock From Chassis No. 0929
A036H0063 1 1 1 1 Clip - Blanking, Without Lock From Chassis No. 0929
050H0723 1 + Column Assembly, With Lock From Chassis No. 1614
050H0724 1 + Column Assembly, With Lock From Chassis No. 1614
050H0730 1 1 1 + Column Assembly, With Lock From ?
050H0731 1 1 1 + Column Assembly, With Lock From ?
2 050H0040 1 Column - Inner Upto ?
A050H0040 1 Column - Inner (With Lock) From ?
B050H0040 1 Column - Inner (With Lock) From ?
3 050H0722 1 Column - Outer Upto ?
A050H0722 1 Column - Outer (With Lock) From ?
B050H0722 1 Column - Outer (With Lock) From ?
4 050H6001 2 Bush - Column
5 050H6005 1 Clamp - Column to Body
050H0051 1 + Bracket - Column Mounting
050H0052 1 + Bracket - Column Mounting
XUFS0412 3 Screw, Bracket to Body
A04W1606 3 Washer, plain, Bracket to Body
L04W0000 3 Washer , shakeproof, Bracket to Body
XUFS0448 2 Screw, Column to Bracket
050H0053 AR Spacer, Column to Bracket
A04W0905 2 Washer, Column to Bracket
YUFN040F 2 Nut, Column to Bracket
7 050H6006 1 + Binnacle - Upper
050H6009 1 + Binnacle - Upper
8 050H6007 1 + Binnacle - Lower
050H6010 1 + Binnacle - Lower
050H6008 4 Screw - Binnacle
9 050M6020 1 + Switch - Dip/Indicators/Horn
050M6019 1 + Switch - Dip/Indicators/Horn
11 036H6055 1 1 1 1 1 Inner Column - Lower
036H6056 1 1 1 1 Inner Column - Upper
12 036H0072 1 1 1 + Inner Column - Upper
036H0073 1 1 1 + Inner Column - Upper
13 036H6038 1 1 1 1 1 Clamp - Upper to Lower Column
036H6057 1 1 1 1 1 Screw, Clamp Fixing
036H6058 1 1 1 1 1 Washer, Clamp Fixing
036H6000 1 1 1 1 Outer Column
14 036H0074 1 1 1 + Outer Column
036H0075 1 1 1 + Outer Column
15 036H6031 2 2 2 2 2 Bush - Column
KSTS0810 4 4 4 4 4 Screw, Outer Column to Facia
A03W0605 4 4 4 4 4 Washer, Outer Column to Facia
16 036H6053 1 1 1 1 1 Escutcheon
036H6033 1 1 1 1 1 Escutcheon
KSTS0410 4 4 4 4 4 Screw - Escutcheons
17 036G6009 1 1 1 1 1 Connector - Horn Push
18 050H2000 1 1 Steering Wheel
050H2000B 1 1 1 Steering Wheel
19 036H6008 1 1 1 1 1 Clip - Horn Push
20 036H6035 1 Nut - Wheel to Column
21 028M0705 1 1 1 1 1 Brush - Horn Connector
22 028H0030 1 Horn Push
23 050M6071 1 1 1 1 1 Switch - Headlamps
24 050M6072 1 1 1 1 1 Switch - Headlamps
25 050H0054 1 Plate - Retaining - Seal
050H0055 1 Seal - Column
26 B050H0055 1 1 1 1 Seal - Column
036B6123 2 Tappit - Plate to Body
27 A036H6064 1 Steering Lock (with buzzer)
28 A036H6055 1 1 Steering Lock (with buzzer)
