Item | Lotus # | All | S1 | S2 | S3 | S3 SS | S4 | S4FED | SPRINT | RHD | LHD | Description | Change Point Notes Bulletin Reference |
1 | 026G0001 | 5 | Road Wheel - Bolt-on | ||||||||||
1 | 026H0704 | 1 | + | Rack and Pinion Assembly | |||||||||
026H0703 | 1 | + | Rack and Pinion Assembly | ||||||||||
036H6027 | 1 | Bellows | |||||||||||
026H0001 | - | Replaced by A026 H 0001 | |||||||||||
A026H0001 | 1 | Lock Stop - Pinion End | |||||||||||
026H0002 | - | Replaced by A026 H 0002 | |||||||||||
A026H0002 | 1 | Lock Stop - Open End | |||||||||||
2 | 026H0005 | 2 | Tie-Rod | ||||||||||
LUFN050F | 2 | Nut | |||||||||||
3 | 036H6007 | 2 | Ball Joint | ||||||||||
4 | 036H6040 | 2 | Clamp, Rack and Pinion to Chassis | ||||||||||
5 | 036H6041 | 2 | Rubber, Rack and Pinion to Chassis | ||||||||||
6 | YUFN050F | 4 | Nut, Rack and Pinion to Chassis | ||||||||||
7 | A05W1007 | 4 | Washer, Rack and Pinion to Chassis | ||||||||||
8 | A036H0061 (W026) |
AR | Shim, Rack and Pinion to Chassis | ||||||||||
A036H0060 | AR | Shim, Rack and Pinion to Chassis | |||||||||||
A036H6002 | AR | Replaced by 050H6012 | |||||||||||
9 | 050H6012 | 1 | Flexible Joint Assembly | ||||||||||
036H6042 | 1 | Plate, Flexible Joint | |||||||||||
036H6003 | 8 | Bush, Flexible Joint | |||||||||||
10 | 026M0038 | 1 | Earth Lead |
