I have a +2 130/5 1972 with the small wooden cover for the fuses on the dash. Does anyone know what the amps of the fuses are, as mine seem to be just all the same and very big!
I can’t find the info in the Lotus Workshop Manual or parts book
I’m not familiar with the 130/5 , but the 4 x4 fuse box set up in the earlier Plus 2s are all 35 amp, except for the single feed to the indicators, which is 5 amps.
You could pull the fuse replace with a ampmeter put the load on and check the amps being used .note a 35 amp fuse is the amps it blows at and would be rated at 17 amp continuous,25A= 12A so depending on the current being drawn you need to go to the next fuse up
Neil
