Front brakes - Help!!
… Hi
As usual , “OEW” is on stands…
Fitting new disks & pads from EBC , every was going fine when testing the car noises appear . The timken bearing were not thighten enough … Back on stand , the problem is the round dust shield in contact with the new -maybe to large?- disk , so the assembly canot be thighten correctly. When folding the shield the problem move to another area because this the bowl area who is in contact.
My questions are , is that dust shield necessary ? have you already had such problem , what will you do ?
Christian.
Hi Old English, Sling’em! I’ve run without backing plates for years, all they ever seemed to do was catch stones, gravel and rubble. I think they were to keep water off in the rain. I’ll be interested to see what others say.
… Thanks for your reply , Sadlotus . So you remove them … That I decided to do this evening … The car down and out for a small tour in the country side … just a pleasure !
I will think to these dust shields later but I am still interested on your solutions … if they are different of me & Sadlotus … !
Christian.
I have removed the dust shields on my Elan many years ago with no problems. I did it mainly to aid disk cooling when racing rather than clearance or access reasons.
regards
I went to a great deal of trouble to carefully modify mine with little air scoops and beautifully cut louvred vents…then I took them off (typical of the many blind alleys in the development of my elan). Better cooling and less unsprung weight. The four pot calipers I now run are a further complication…for another thread.
Patrick
I would be very interested to hear about your work with four pot calipers. I am currently looking at something similar.
… Seems that everybody is doing the same … to the bin !
So , have you notice how heavy are the originals calipers ?
I don’t speak about efficiency (not yet…) but what can be done for that ? Did you already write on this ?
Christian.
Currently I have fitted the +2 front brakes (bigger disks and calipers) to my S4 Elan. This has certainly helped and the brakes are much better; reduced fade and improved f/r balance. However as you say the calipers weight a lot, about 5kg each! Could certainly loose a bit of unsprung weight by switching over to an alloy caliper. The same goes for the rear too, just need to figure out a handbrake mechanism :confused:
Hi Christian,
The shields are fitted for a few reasons
  1. To stop dirt/stones being thrown up on to the disc
  2. To reduce a film of water building up between pad and disc - typical problem on wet motorways
  3. heat shield for rubber suspension boots
Positive side is much better cooling
I would remove them but if you have the inclination make up a small shield to protect the rubber bits
