Hi all,
This isn’t the bouncing Tach question! I am replacing the heater in the Plus2. Whilst the dash is out I had a look in the back of the tacho.
The sense wires are fried! The insulation is all melted, but the wire core is still intact.
My question is this: The sense wires through the tacho inductor coil are melted together. Does anyone has a picture of the internals that I could have a look at please? BTW the tacho IS still working!
Thanks Mattias,
But you seem to have a different tach to me! My sense coil is much bigger!
Mine is from a 72 +2.
Thanks for the pic any how much appreciated.
Jeff
Mine did the same thing. Not sure why. If you take a knife to the melted insulation and cut it off, you will find that the wire core loops through the inductor coil a couple of times, that’s all. Nothing real high tech about it. Good luck.
DIY.
I looked for a smiths RVC gauge on EBAY with the same sweep and same rev range…
Then just swapped the internals…
Needed to drill some small holes in the face and case.
Couldn’t replace just the dial on the new gauge as the case didn’t have the fittings for the ignition and main beam lamps…
The new case also wouldn’t accept the +2 bezel
