Flywheel Weight
Sorry to be a bore,but has anyone got to hand the weight of the twincam flywheel
Thanks in advance
I just replaced my stock flywheel and ring gear with an aluminum Fidanza flywheel. The stock flywheel and ring gear is 14 lbs.; the Fidanza lightweight flywheel and ring gear is 8 lbs. (I’ve noticed no loss in driveability.)
Gary
'71 Elan Sprint
Gary-
Are you able to confirm the 14lb weight of the original? Was it an unmodified original?
That seems light relative to my vague recollection…and I don’t have one “out of the car” to verify.
Probably just my memory fading in my old age…
-John
just weighed flywheel from stock 1558 standard '66 twincam.
Weighs in at 16lb (sixteen pounds) with starter ring gear & clutch location dowels.
John, assuming my scale is correct, the flywheel on my Sprint that I just had replaced two weeks ago weighs 14 lbs including ring gear. I assume its stock, but I’m the third owner so who knows. Looks stock to me.
Gary
'71 Elan Sprint
