Jon
They are exactly the same as the standard ones except for they are slightly smaller above the plate that goes onto the chassis, so you will see more bolt above the mounting (under the fuel tank!)
You will need 1 washer only if you are now fitting the brace. Sequence is the same
Me too. The issue is whether or not there is room to put the additional large washer between the brace and the underside of the mount.
Although there isn’t much clearance between the underside of the diff and the chassis, I don’t get any knocking. It seems to me that the way the TTR mounts work is that the mount allows each of the diff lugs to lift from its rest position under load but not to droop further. The diff can therefore rotate slightly (along an axis in line with the prop) in both directions because either one lug or the other can lift slightly. To avoid the diff hitting the chassis, the priority is therefore to give it clearance at the top rather than clearance underneath.
Cheers, guys - this is pretty much as I intended and if it works I will do it this way!
I was just a little confused as to how the diff mounts work because, by virtue of their design, they are effectively sandwiched between the large top washer and the diff brace/bottom washer
