Fitting new GAZ rear dampers (inserts)
My rear struts are probably unique / barking, dependant upon your POV.
The damper itself is shorter than the original and I thought it might be a problem until I finally
realised what the fat washers were for.
Having cleaned up the tube thread I filled with ATF and screwed in the inserts.
Then the alloy threaded tube which comes flush with the steel one.
Next problem was the alloy “bump” space could not be attached to the new hexagon damper retaining nut. I fixed it with epoxy resin to the alloy threaded tube + a couple of turns of duct tape. It will turn with the tube when adjusting and “should” be OK.
With the tube adjusted virtually to the bottom the spring and top plate can be fitted without compressors.
Hopefully, as I’ve made up a hard wood block to hold the damper rod as full extension, it will be easy to fit the strut in place.
