STARTING THE ENGINE:
Once the sensors are all working, injectors and coils all firing, engine timing synchronized with the ECU, and Fuel pump is delivering fuel at the relevant pressure to the injector it is time to try starting the engine. This first start may be tricky so be patient. On the maps the important cells for starting the engine will be the 0-4% throttle opening at 750-1500 rpm so only 6 cells need to be optimized to begin. The timing can be set to the initial timing advance for a twincam (remember the number is the total advance which in a traditional distributor would be static + any dynamic timing). Later you will generate a 3D timing chart (probably best done on a rolling road).
The fueling table in this area is a bit of a guess to begin.. I began with putting â8â in the cells on the top left (I amusing the pico injectors from QED). This is very rich but helped the initial start. I also sprayed some ether into the inlet to help things along. Pressing the starter got the engine firing and after a few firings then dying the engined fired up and I reduced the fueling to closer to 4 (to do this enter 4 in the greyed out cell, the grey cell is closest to where the engine is running) and press F4. I modified this number until the engine ran smoothly and then let it run up to temperature. As the engine warmed I reduced the fuel (like pushing in the choke).
Now I was lucky the engine fired pretty easily. There are other scenarios .
1) If the engine does not fire at all even with ether then check your spark and fuel and if there is spark check the synchronization (you can see whether synchronization is working by looking at the Diagnostics Display in Diagnostics Information Menu) and the Sensor Position figure in Engine Settings under the Engine Configuration men u.
2) If it backfires, check the synchronisation and the Sensor position figure in Engine Settings under the Engine Configuration me nu.
3) If the engine fires and dies, check the idle setting on the Throttle bodies a little and/or add a little more f uel.
4) If the engine fires and the idle is too high (you may need to switch of quickly if this happens) close the idle setting on the throttle bodies.
Once the engine is up to temperature and idling at a reasonable value you can check the AFR (see AFR meter in Live Data or the AFR meter on the Dashboard). Ideally you want this between 13-14:1 AFR or 0.9-1 Lambda. You can achieve this by altering the grey cell on the fueling map. Reducing the value weakens the mixture increases the AFR and Lambda. Make modest changes (say 0.2) and then press F4 to send the new value to the ECU. If you go too far the engine may falter or stop so just go back to the original value. Once you have a steady mixture in the required are you may also have changed the idle RPM which you will notice has changed where the grey cell is located. For now alter the idle adjustment on the throttle bodies to compensate (later on you can use the ignition based closed-loop system to control idle speed).
Now that the engine is idling you can try blipping the throttle gently to see if it responds. The initial Q360 map from QED seemed to work ok here and my engine revved freely. Now you have the engine up and running give it a good check for leaks etc. and check the fan goes on if you have connected it to the ECU. At this stage I stopped the engine and went for a celebratory cuppa!
NB: restarting from cold now may still need you to manually add some fuel to the map and remove it (manual choke
) or add some ether to the inlet but you should now be able to start the car at will and it should progress to idle. It is quite possible that the idle you set when the engine is warm, using the idle screw on the throttle bodies, might be too low an idle as the car is warming. To resolve this you will need to set up closed loop, ignition based idle control.
