Felt, its use?
I am presuming the felt material below the carpet, above the body. Is there for sound deadening. Or is it there for water absorption, or as your funny Brittish comedy troop Monty Python might put it. ?Super water absorbent?.
My foot carpet piece comes up and is fairly easily dry able. But I believe the rear of my +2 is less easily dryable.
Throughout my elise I have used the dynamat type product, for sound deadening. Along with some undercoating spray to keep vibration hum down.
The simple question. The value of felt, might be more useful if I consider I will use it for extra cushioning. Because it seems to simply mould if not dried properly. Or maybe I wash my car too often and dont dry it properly. Or water creaps in from somewhere…
I also dont know if the originality of felt is so important. Nor if the synthetics have any benefits in an elan.
It’s there for sound insulation. Maybe heat as well (to keep engine heat out of the cabin).
If you have a leak, it is better to hunt it down than put up with wet carpets and condensation.
My view FWIW is that “originality” is less important that “utility” for a hidden thing like this, but then, I’m not a purist. I found most sound proofing mats to be ruinously expensive so I still have the old ratty felt in my car. Interestingly, the felt on the side panels and round the fuel tank area is like new, unlike the underfloor and boot felt, which is all completely gone.
I bought a roll of felt from woolies.
woolies-trim.co.uk/product/ … ening-felt
I even used it on the inside of my roof between the headlining rods and it made a massive difference.
An alternative is to go the the local dump and strip the soft padding from the top of a dumped divan (before it gets wet!) It is usually a thick layer of woven recycled/shredded cloth, I used that to insulate a TVR on a budget.
I used felt to sound deaden a new Kia and an old Jimny, it works well
I found that water in the footwell came from poor bulkhead grommets , but mostly from the top of the door to body. You need some rubber seals there that usually vanish during paint jobs…
Once I realised this I put some seals in and had dry footwells…
My boot however is using bituminous roofers seal (fake stickon lead flashing) it deadens sound perfectly and allows the leak from my bumper bolts to drain away…it has a sticky side and a fake lead side so it looks ok…
wickes.co.uk/Wickes-Self-Ad … m/p/243007
i’d say: follow colin’s philosophy: no unnecessary weight, even when you prepare a touring car (e.f. BTTC) the first stuff you get rid of is carpets, felt, radios, AC, one seat, door cards, etc etc… basically no interior and macrolon windows… PLUSor btw: some of us buy TCs because they love and want the FREE NOISE!! sandy - THE unpurist!
Brian Buckland says:
Instead of felt you may consider using ? inch neoprene sheet which will not absorb water and thus is better corrosion wise for the chassis.
Ah, but is not Mr. Buckland referring here to the felt saddle twixt body and chassis, rather than carpet underfelt? +1 for dynamat and keep your classic car in a garage where it’s nice and dry
:stuck_out_tongue:
Yes, a dry roof and foot we have
I had used the Chinese dynamat. About 1/3 the cost
Nope, no radio. I am considering running bonnetless as the sounds a twink makes is riveting. And most likely side pipes behind the front wheels. Also to save the old weight
Here in BC Canada. We can apply for altered vehicle stats. Which would allow us to run Polycarbonate wind screen. Will keep you posed on when I make a move on this project.
