FB - Gearbox - Internals
Item Lotus # All S1 S2 S3 S3 SS S4 S4FED SPRINT RHD LHD Description Change Point
Notes
Bulletin Reference
1 105E7160 1 Snap Ring
2 105E7026 1 Snap Ring
3 69GG7025 1 Bearing
4 2821E7017D 1 Main Drive Gear (semi close ratio)
A028F0020 1 Main Drive Gear (close ratio)
5 113E7120A 1 Bearing - input shaft
6 2821E7061C 1 Main Shaft
7 353080S 1 Ball - 5/16" dia.
8 E436GA1 1 Housing - Bearing
9 306305S 1 Pin - Bearing Housing
10 113E7065 1 Bearing
11 113E17288B 1 Spacer
12 2821E17285 1 Speedo Gear
13 111100ES 1 Tab Washer
14 114470ES 1 Nut
15 l05E7041D 1 Bearing - Extension Housing
16 69AG7A292AA 1 Seal - Extension Housing
17 2821E7071B 1 Washer Added 2/18/08 from Elan+2 Manual
18 2821E7100A 1 Gear - 1st speed (semi-close ratio)
113E7100C 1 Gear - 1st speed (close ratio)
19 2820E7107-A 2 Synchroniser Ring - 1st and 2nd
2824E7107-B 2 Synchroniser Ring - 1st and 2nd
20 2820E7124A 1 Synchroniser Assembly - 1st and 2nd
69BG7124AA 1 Synchroniser Assembly - 1st and 2nd
2821E7K080B 1 Snap Ring - 1st and 2nd - synchro
E457GA-1 3 Insert
2824E7116A 3 Insert
211E7109A 2 Spring
21 2821E7102A 1 Gear - 2nd speed (semi-close ratio)
A028F0024 1 Gear - 2nd speed (close ratio)
22 2821E7B340B 1 Gear - 3rd speed (semi-close ratio)
A028F0026 1 Gear - 3rd speed (close ratio)
23 113E7107D 2 Synchroniser Ring - 3rd and 4th
2824E7107B 2 Synchroniser Ring - 3rd and 4th
24 2820E78280A 1 Synchroniser Assembly - 3rd and 4th
69BG78280AA 1 Synchroniser Assembly - 3rd and 4th
105E7116B 3 Insert
2824E7116B 3 Insert
2820E7109A 2 Spring
25 103E7059B 1 Snap Ring
26 149686ES18 1 Spacer
27 105E7129B 4 Washer
28 E0A7121 40 Roller - needle bearing
29 2824E7113B 1 Gear - Counter Shaft (S/C/R)
A028F0034 1 Gear - Counter Shaft (C/R)
30 105E7128B 1 Washer - Counter Shaft
31 2820E7111A 1 Shaft - Counter Shaft
32 211E7140B 1 Shaft - Reverse Gear
33 2824E7142 1 Gear - Reverse idle
113E7143 1 Bush - Reverse Idle Gear
