When I drive my Elan, I always end up smelling like I bathed in exhaust fumes, even though the car is open.
I have had a few people tell me that is the nature of old cars because the aerodynamics bring the exhaust fumes into the car.
Two points. 1) confirm that the boot gaskets as sealing the lid properly. When mine was not right all sorts of fumes were sucked in. 2) Is your tail pipe short? Extending it beyond the bumper will help get exhaust fumes in the air flow instead of the vacuum behind the car.
Another possibility: There’s a tube that vents the head (I think) that is supposed to connect into the carb airbox. Mine doesn’t and vents into the engine bay. Hence, my '67 S3 is probably smellier than it needs to be, although my car really doesn’t smell very much.
Hi Morgan,
I also had fumes inside the car. My shift lever rubber boot finally split open and I was getting strong fumes from the engine in my coupe even with the windows open. I sealed it up and added a new rubber boot and the problem was taken care of. Just another possible cure.
I take it that your lotus is back on the road again with its new found power.
Any new pictures??
I have a supertrapp on my S4 FHC and I don’t get exhaust fumes in the car.
I did a bit at one point on the stromberg engine because I had an exhaust leak at the header to head interface.
Again, the things to check are:
Crankcase vent going to intake plenum
firewall holes such as speedo cable hole grommetted and sealed well.
Exhaust leakes from Head to header and any couplings (you can usually hear these
gear shift boot should have it’s slot all the way into the metal plate screwed to the tunnel so it seals well.
Boot lid seal intact and any openings between the boot and the interior sealed (there are drain holes in the bootom of the boot on my car).
Whoever it was who was commuting across London in his Elan a few years ago had a terrible time keeping the exhaust fumes out of his FHC. I can’t remember what he found in the end was the source.
That is one nice thing about modern cars. The Catalyst burns up all the stench so even if a few fumes come in they are not noxious.
Preliminary investigation leads me to believe it is the crankcase vent, as I don’t run the airbox and the tube is venting into a catch can in the engine bay. Will have to change that
