Can someone point me in the direction (in the UK) of an engine cradle similar to photo that will fit the Twink engine.
thanks
thanks
Motorsport-Tools.com, page 116 of their catalog, 45.58, not including VAT. Escort catalog.
Hi Mark,
I made this up some time ago.
The block is attached via the engine mounts. It can be rotated 360 degs, and locked in various positions by a bolt through the flange.
I use these furniture moving dollys as storage for engine and other heavy components, good if you need to move items around due to limited storage space and only about $20 at the local Bunnings ( Home Depot equivalent). If you need to you can use a ratchet strap to hold the item stable on the Dolly for a few more dollars.
Check the Historic Formula Ford forums. The mounts are identical to the Kent FF engine and very popular.
Years ago, I happened to show my 15 year old son I was looking for a pair. The following Friday afternoon a pair showed up in our garage. He built them in his metal shop class from scrap steel and a mig welder. I still use them.
Might be worth a punt around the Caterham mob
When I built mine in the 90’s it was delivered with the 1700 cross flow on the same frame / cradle set.
They lived in my dad’s garage for years but I think he eventually threw them out.
I had this fabricated locally, based on photos of a cradle sold by a Formula Ford parts supplier. I use it for the Vegantune motor I had built for me in 1977, but replaced with a QED unit some 20 years ago. The wheels make it easy to move the TC around.
Andy
I have purchased a number of a similar product in the UK. For the price, I thought they would fall apart, but they have proved very durable.
Might be worth checking with Dermot Healey, he sells a load of competition bits and pieces have a look on the uphill racers for sale page he was offering a pair of Ford spec frames for £45 a couple of weeks back.
See if the link thing works.
Hi guys,
Got a cradle thanks
Which one did you choose?
Burtons… only one available easily
