I vote for Lumenition optronic.
I have it on my Sprint and I have used Lumenition on classics for years.
Burton Power usually do them at a good price.
(I also use a sports coil and some Magnecore ignition leads)
[quote=“bcmc33”]
What level of power increase does electronic ignition give?
/quote)
In my opinion electronic will give no power increase IF the original system was in good condition with everthing working as it was supposed to, it WILL be more relieable and will need less maintainance.
Yes I’ve heard these wonderful stories that after elec. ign is fitted the car goes so much better but I would question whether the ign. system was working correctly to begin with.
I am only speaking of case’s where only the ign system is changed, if a different distributor is used then it could make a difference.
I use Lumenition and have never had a problem so cannot comment on other systems.
I would vote for Aldon Ignitor, Pertronix, or the Lumenition Magnatronic, all very similar, all fit within the distributor, and super reliable. I have used all three for some years and never had a problem with any of them. I can’t say the same about the more expensive Lumenition, unfortunately !
No power increase whatsoever over a properly set up points system, but as the previous guys suggest, it’s fit and forget.
