And do that by taking the cover off one of the carbs and checking that the float bounces up and down when you poke it, ( carefully…), with a thin wire. If it doesn’t, you’re not getting fuel through.
Then pull a plug wire, hook it onto a spare plug that’s resting on the cam cover, use the push up button on the bottom of the starter solenoid, and see if you’re getting a spark.
